I don't see a physical fuse either. The users manual doesn't say anything about a fuse, but on the back of the machine it says replace with a 20A tile delay fuse only. I've taken this thing apart and don't see it. Unless it's a wire fuse. But none of the wires I see say fuse on them. I've emailed the company, but currently completely lost.
Posted on Mar 10, 2023
It is possible that some models of Sedona dehydrators have a fuse, but it is not a universal feature of all Sedona dehydrators. I recommend checking the user manual for your specific model of Sedona dehydrator to see if it has a fuse and, if so, where the fuse is located. If you do not have the user manual, you may be able to find it online or by contacting the manufacturer for assistance.
If your Sedona dehydrator is not functioning properly and you suspect that a fuse may be the cause, you can try checking the fuse to see if it is blown. If the fuse is blown, you will need to replace it in order to restore power to the dehydrator. Be sure to use a fuse with the correct amperage rating as specified in the user manual or by the manufacturer.
Posted on Jan 06, 2023
Here it is
