Kitchen Appliances - Others Logo
Question about Pitco Frialator Kitchen Appliances - Others
Pitco fryer showing heat failure even when the pilot light is on?
The Pitco gas fryer always displays a heat failure on the screen.
ADMIN Andrew
    Top Expert:
  • Pitco Frialator Master
  • 57,345 Answers
Question moved from Misc
HEAT FAILURE - This means the heating system has failed to respond, which can occur because a high temperature limit switch has been tripped and needs resetting. On gas deep fryers, "HEAT FAILURE" may display if the pilot fails to light or if the pilot flame is too weak as detected by the ignition module.
Pitco Fryer Error Codes and What They Mean - Parts Town
Posted on Jan 05, 2023
My pitco fryer SFSG18 will not light it has spark but does not seem to be getting gas when trying to light
Have you tried inspecting/replacing the thermocouple? This is the thing you heat when initially lighting the pilot.
You may also have a stuck pressure valve, but that is unusual.
Pitco fryer
Hi there!
Try to check first the incoming and running gas pressure, it must comply with the rating on the unit's nameplate.
Regards
When the pilot light button is released the flame goes out. (pitco propane fryer) - unsure of model number as data plate is worn. Does the thermopile need replacing ?
Try first to clean the thermopile. If it has accumulated soot/ carbon, it will not sense enough heat from the pilot flame to generate small amount of electricity to energize the pilot valve and main valve of gas valve.
.poilit light on but not burnner on even i turn
Check if the gas valve knob is set at "ON" position after lighting the pilot. Check also it the thermopile is receiving enough heat from pilot flame and try also to tighten all wiring connections on gas valve, thermostat and hi limit. If these do not seem to correct the problem, you have to replace the thermopile.
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
My pitco 28lb countertop gas deepfryer conv to propane it will l
Check if the flame quality of the pilot is good. Small amount of voltage generated by thermopile used in energizing pilot main valve coil during fryer operation relies on the quality of pilot flame, also, the thermopile itself should be free of soot or any form of dirt in order for it to absorb the heat from pilot flame.
Check also the gas pressure, it should meet the gas pressure required on the nameplate.
Pitco Fryer will not light up
Check the thermopile, it must be free of dirt or soot so that it can absorb enough heat from pilot flame and in turn can generate the right amount of voltage to energize pilot and burner coils.
Check also the gas pressure, it should be of standard as required on the unit's nameplate.
Pitco frialator (propane)
Better check the incoming gas pressure first, it should match the requirement as stated on the nameplate. Low gas pressure will make the pilot flame small until it could not heat up the thermopile which will shut both main burner and pilot flame.
1helpful
Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
