Sewing Machines Logo
Question about PfaFF Sewing Machines
Pfaff 7550 creative only sewing in zig zag stitch. The display is stuck in one stitch only and only in one size. None of the button functions are working. I have changed the batteries however this has not resolved the problem. Please help ? Many thanks.
Posted by Ferhat Yasin on
Bashar Telesi (TerraceDS)
    Novelist:
  • 200 Answers
It sounds like your Pfaff 7550 Creative may be experiencing a hardware-related issue. To diagnose the problem, try resetting the machine by unplugging the power cord and waiting 10 minutes before plugging it back in. If the problem persists, then it is likely that the machine's control circuit board may have become damaged and will need to be replaced. Additionally, you should also check that the machine is receiving power by testing the power cord, power switch, and the foot pedal. If all of these components are working correctly, then the control circuit board will need to be replaced. If you need further assistance, you can consult a professional Pfaff technician for diagnosis and repair.
Posted on Jan 06, 2023
I bought a Pfaff 6122 and it is so clean it looks like it has never been used, however, none of the stitch buttons will do anything. It is quiet and sews straight stitches, but no others. WhY?
On that machine you need to set the “width” knob to 5 or 6, as well as select an appropriate stitch to achieve a zig zag type stitch.
2answers
On Pfaff 7550, Menu button is stuck/ has lost its play. Absence of play prevents choice of stitches on display which does show. Reverse or Needle down, etc. buttons do not function when Menu is stuck.
Hello, Victoria -
I suggest you locate an authorized Pfaff sewing machine repair business near you and take the machine there for evaluation and repair.
Best wishes.
1helpful
2answers
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
2answers
Pfaff 360, how do I stop the zig zag stitch on my machine?
could you explain more about what the machine zig zag stitch is doing or not doing?
Neddle hits bobbin case while sewing zig-zag stitch on Pfaff 7570
insert the needle all the way up or, lift the needle shaft or readjust the timing
1helpful
I have inherted a Pfaff 7550 and do not know how to use the maxi stitch function or to enlarge embroidery stitches
Contact a local Pfaff dealer for a manual or ask if they have lessons.
This is not as easy as the spoken word.
1helpful
2answers
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
