Expert
- Posted on Jan 03, 2023
Re: Emerson LC320EM1F no display
- Check the power supply: The power supply is responsible for providing power to the various components of the TV. If the power supply is damaged or malfunctioning, it could be causing the issue you are experiencing. Test the power supply to see if it is functioning properly.
- Check the main board: The main board is the central hub of the TV and controls many of its functions. If the main board is damaged or malfunctioning, it could be causing the issue you are experiencing. Test the main board to see if it is functioning properly.
- Check the display panel: The display panel is the component responsible for displaying the image on the TV. If the display panel is damaged or malfunctioning, it could be causing the issue you are experiencing. Test the display panel to see if it is functioning properly.
