Computers & Internet Logo
Question about Acer Computers & Internet
Can the iGo Green laptop wall charger charge the Acer Aspire A515-55 laptop?
I have the iGo Green wall charger but I don't have tip #702. None of the others fit this laptop model. I was asking before I try to buy the tip #702.
Posted by Kadeesia M on
ADMIN Andrew
    Top Expert:
  • Acer Master
  • 57,147 Answers
Question edited for clarity iGo, not Exclamation !Go.
Yes it is a 90 watt charger so yes it is fine if you can get the right tip to fit
https://www.google.com/search?q=!Go+Green+laptop+wall+charger
Posted on Jan 01, 2023
  • Kadeesia M
    Kadeesia M Jan 02, 2023
    Thank you.
  • ADMIN Andrew
    ADMIN Andrew Jan 02, 2023
    You are very welcome :>)
The charging light remains red and never show green. Even when left for days to charge, it will say 83o/o left every day and i don`t no what the cause is.
Either the charger is damage or the battery is damaged and need replacement of any one of it.
But try to borrow first the charger if you have a friend and check if it is charging?
When I plug my acer laptop charger into the wall, the green light lights up accordingly. when i plug it into my laptop the greenlight begins blinking and my laptop does not charge. is something wrong with...
The solution for this problem is the "Mosfet" located near the daughter board of the laptop. just replace the "Mosfet" with new one and you laptop will start charging the battery.
Laptop will not turn on and when you plug in the
You may have a DC Jack issue and needs to be replaced. Common with Acer models using the yellow DC jacks.
And since the battery will not charge, it is most likely a component issue. Shorted MOSFET in the charge section.
4helpful
Wont charge
1. Check your Wall Jack! Is it working with other electric gadgets ? If it's not working, then problem is with the wall jack!
2. Check your Charger! Try another charger of same model to charge your laptop. If laptop is charging by another one, then replace your bad charger!
3. Check your Battery Pack! Is the battery in good condition... any type of smell or liquid coming out of battery ? If that's the case, replace the battery pack with a compatible one!
4. If none of the above steps helps, then the problem is with the power supply unit of the motherboard. Contact any authorised Acer Service Center for the repair / replacement of the Motherboard!
5. If your system is still under Warranty, you should opt for the replacement of motherboard !
please rate this advice if it helps...tc! :)
3helpful
2answers
My acer 5735 won't hold a charge. Seems to charge (green light)
if it doesnt hold a charge its degraded and will need to be replaced . people dont realise that keeping a laptop plugged in damages the battery
2helpful
The battery won't charge on acer aspire 3610. I replaced battery with a new one which arrived with 65% charge. I fitted it and laptop worked until no charge left. The charger is plugged into mains and...
check the output of the charger and see if it is charging if so the conector might be bad does the plug wiggle when it is plugged in? it should feel very solid
2helpful
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
3answers
Need to replace wall charger for portable dvd -PDV-702
Well, you could bring it in to radio shack and have them check what type of tip you need, and then just buy a universal charger with that tip included.
Steve Sweetleaf
Steve Sweetleaf
shadow
