Question about Panasonic Viera TH-42PX80U Plasma TV
Cc box my cc box is one the center of monitor (panasonic tc-p50x1)
Posted by ewa_orszulak on
Anonymous
    Problem Solver:
  • 17 Answers
Open the menu, then go to setup, there should be a closed caption options in there, also remember that CC can only be passed via a transmitted cable signal. If you have a Cable box or Satellite box connected via HDMI, or its pushing a HD signal (720p, 480p) the CC box is from the Sat or Cable box, test the settings on the box.
Posted on Sep 22, 2009
Panasonic tc-p50x1 8 red flashes
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1helpful
1helpful
2answers
9 blinks on panasonic p50X1
9 blinks Panel Config. SOS. Check it. If you wish to get more details, check the site linked here. Pull up older posts.
I have a Panasonic Viera TC-P50x1 HDTV. When I turn the power on the red light blinks 10 times. What is my problem?
Unfortunately the set will need serviced. I would contact Panasonic or whoever you purchased it from for warranty information.
What should i put my settings at on my Panasonic Viera TC-P50X1
Standard or normal,because u can change colors or setting,extra..
I need to know how to hook up my stereo system to my panasonic tc-p50x1 tv
the audio output on the back of the set goes to the audio inputs on the stereo.
depending on age it may have aux,cd,tape,vcr,video inputs.
they will all work,as they are made for a 300mv to 1 v signal.
the one that will get overdriven severely is the phono input,never use that one except for a turntable.it is made for a 3 to 5mv signal.
a moving coil input is even more sensitive, about.1/2 mv.
4helpful
Need owners manual
http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/model.TC-P50X1
Panasonic Viera TH-42PX80U Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
