Similar to most Beogram 1800, the RX 2 featured record sizing by weight. When Play was selected, the centre part of the platter would raise gently, with only just enough force to lift a 45RPM single. An LP would be too heavy to lift, so the mechanism would set itself to 45RPM and 18cm if the record lifted, 33RPM and 30cm if it did not. The speed control keys could then be used to override the choice for non-standard records. The parts could also detect if a record was not present, and prevent the turntable being activated
Just put lp on and it should work
Check the connected speaker/s first. If found OK, the power amplifier section circuit inside the Amp: is faulty. Contact any service technician to get it repaired. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
If you can her the motor turning, there is a good chance that the belt(s) have broken and need to be replaced. If you hear nothing, then there could be a control issue. I'm leaning toward the belts though. Figure on $5-$15 for the belts,
Generally speaking, you select the station you wish to store, then depress and hold down the preset button you wish to store it to. After a few seconds, the screen will blink, and the will be station stored. On to the next one. Try this and see how you get on. If you have any problems, I am happy to help you help you sort it out. Cheers
This is something I can tell you that you can sort out yourself with a little bit of mechanical aptitude and a couple of screwdrivers.
FIRST turn the power off to the unit.
If you pop the lid off the unit, you will see that the capstan drive belts to the tape decks mechanism have failed, Either turned to back muck like windscreen sealant, or just broken and dropped off. The belts (each deck has one) will need to be replaced. The part number for the belt(according to my records) is REB1272 You should still be able to get them from Pioneer spares directly in your country. Let me know where you are and I can get some better information to you.
good luck. Happy to assist you further and answer any questions you may have.
