Cell Phones Logo
Question about Cell Phones
How do you unlock the keypad of young model 26800? I have tried 1st method it doesn't work. Can anybody help me with this issue?
Posted by Rex Ivan Amamag-id on
  • Wizard Dec 30, 2022
    The Young Model 26800 keypad can be unlocked by holding down the ‘A’ and ‘B’ keys at the same time for three seconds. If this does not work, you may need to enter the encryption code on the keypad to unlock it. To do this, press the ‘A’ and ‘B’ keys, then input the password. If you do not know the password, you will need to contact Young support for assistance.
  • Mentor P
    Mentor P Jan 02, 2023
    To unlock the keypad of a Young Model 26800, you will need to use the factory reset code. The factory reset code is a special code that is used to reset the lock to its default settings.
    To use the factory reset code, follow these steps:
    Turn the lock to the "Unlock" position.
    Press and hold the "*" key on the keypad.
    While holding the "*" key, enter the factory reset code. The factory reset code is typically a series of numbers, such as "123456" or "654321".
    Release the "*" key. The lock should be reset to its default settings and the keypad should be unlocked.
ADMIN Andrew
    Top Expert:
  • Cell Phones Master
  • 57,455 Answers
2answers
How to unlock samsung galaxy young (GTs5360)too many pattern attempts
If you kust Google this option there are a few options. I have provided the 1st two here.
How To Unlock Samsung Galaxy Young and Samsung Galaxy Young DUOS
http://sim-unlock.net/simlock/Samsung/Galaxy_Y_S5360/
1968 nuvox 7000cb
The microphone circuit is overdriving. This is an internal issue.
My lg ke 990 it doesn't work with sim card sir . please helpe me too.
Model : LG KU990 Viewty & KE990
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
1helpful
I have a chamberlain garage door opener and we accidentally hit the lock button and need to unlock it from the keypad - is there a way to do this?
The lock button doesn't affect the keypad. In other words when the lock function is turned on the keypad will still work but your handheld remotes will not. I suspect you have other problems.
1helpful
How do you unlock security codes for LG its a 4 digit code ?? i forgot my code for my phone
Am not sure what model LG phone you are trying to unlock but here is the steps to unlock password
1st method- Turn off and turn on the phone and then type ##3282# into it real fast, before it sets itself and you can find your code under advanced/view/lockcode
2nd method - if the model is LG secret Insert your original sim card and Enter 2945#*750# Select sim unlock in the popup menu Enter unlock code and press ok LG secrete will reboot and it completes the unlock.
Nokia 6600 keypad malfunction
TRY THE MANUAL FOUR BUTTON PRESS FORMAT THAT IS SWITCH OFF YOUR FONE, THEN PRESS DOWN *3 THE GREEN BUTTON AND SWITCH ALTOGETHER AT ONCE AND HOLD DOWN TILL SCREEN DISPLAY FORMATTING
Aug 24, 2009 • Nokia 6600
Forgotten unlock code.
try the last 4 digits of the phone#
18helpful
Sharp Carousel Model R9H84B
I've attached the portion of the manual which shows how to lock & unlock this model.
If that doesn't work, unplug the oven for one minute, plug it back in aga9in, then try again.
If it still doesn;t work, then your keypad has failed, and they are no longer available for these model, so the oven would have to be retired.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
N95
hello!
1st try to open the case and adjust the position of your keypad
2nd if issue is not solve check if the clicker or your keypad can reach the phone clicker which is 1 & 8.
if not better change your keypad.
-DOC
Top Cell Phones Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Cell Phone Expert? Answer questions, earn points and help others
