Has power red light is on Won't turn with remote or pressing power button on TV. Did the unplug for 60 seconds pressed the power button for 30 seconds within the 60 seconds, that didn't work. Changed batteries in remote, same problem. Other DIY suggestions need the TV on, well mine doesn't turn on.
I'm sorry to hear that you're having trouble with your TV. Here are a few things you can try:
Hey Tony, there are 2 things that can cause the issue your seeing, I want to double check one thing, when you say the standby light is on you mean it stays on, it stays on steady and doesn't blink, when you push the power button on the tv? If it blinks we need to go down another road however this model and many other models of Funai brand sets have main board issues, it's possible your power supply is bad however if you're getting standby voltage and you are if you see a standby light that means the hot side of the supply is working and that's where about 90% of power board issues are. Go to shopjimmy.com and put the model number of the main board in the search and see if one is available, as a last resort look on ebay but I don't advise buying boards there.
Hope this helps, one other thing, if you can't fix it yourself you might as well recycle it as taking it in for service will run close to the cost of a new set.
