The screen is multi color rectangles. Sound still works but picture is not visible. I have unplugged it overnight, and tried again. Still the same issue. Is there a board or easy replacement part to fix this TV?
Tv boards are fairly easy to replace. usually there are 2. one is the power board. should be obvious to see as the wire that plugs into the AC wall outlet is connected to it. The other will be the one your needing. Look on the board and find the part number. Then the search begin. Let me know if i can help further.
Posted on Jan 07, 2023
SOURCE: No picture on 42" plasma TV.
take your tv to a tech the tv is having problem in the color circuit and the vertical circuit.
Posted on Apr 14, 2007
SOURCE: RCA HD52W59YX35
just found the problem fuse that causes this to happen. The set I have
also was not converging, and the auto convergences option was also
gone. The small fuse labeled fl231 which is right next to the big
plastic piece with the large red wire coming from it in the left corner
of the circuit board closest to the back. It is the middle
of the 3 small fuses that are smaller than a Chiclets gum. I was
able to pull up the circuit board and jump the fuse with some alligator
clips and the set looked great again. Every one says watch out for the
unit with that red wire SO WATCH OUT!
damortch check out mouser.com I think I found them on there gonna call them tomorrow to see if I can get mine there.
Posted on Dec 28, 2007
SOURCE: RCA SCENIUM TV (HD50LPW175) NO PICTURE.SOUND FINE.
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
SOURCE: RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Posted on Mar 24, 2008
SOURCE: Multi color vertical lines on sony wega LCD tv/42 inch
sir do a power reseet ,turn off the tv then unplug it from the electrical source then wait for 1 minute then plug it in and turn it on if it doesn't work call sony customer serveice at 1800 222 7669
Posted on Nov 07, 2008
