Question about Pioneer Audio Players & Recorders
The receiver is getting power and the indicator light at the power button lights up. When the power button is pressed, can hear a relay clicking (just one clicking overall) then there's nothing, no display, no audio. I think the main control board is not getting power and I'm not sure which part of it might be reason. Might be other reasons too. Someone help guide me to fix this issue.
It sounds like you are having an issue with your Pioneer VSA-5500 receiver not displaying or producing any sound. It's likely that the problem is related to a malfunctioning main control board or a power supply issue. Here are a few things you can try:
It's important to note that troubleshooting and repairing electronic equipment can be dangerous, especially if you're not familiar with the device, so it's best to contact a professional technician if you're not comfortable working with it.
Posted on Jan 14, 2023
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
