Dryers Logo
Question about Dryers
F2E1 light is on but all buttons work
My new...1 year old gas cabrio dryer (Whirlpool) will not run. Getting this F2E1 code.. but all keys on keypad work.
Posted by rita reichert on
Anthony
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 419 Answers
The F2E1 error code on a Whirlpool Cabrio dryer indicates a problem with the user interface control board. Even though the buttons on the keypad appear to work, there may be an issue with the board that is preventing the dryer from starting.
One potential solution is to try resetting the dryer by unplugging it from the power source for at least one minute, then plugging it back in and attempting to start it again. If this does not resolve the issue, it may be necessary to replace the user interface control board.
It is recommended to contact a qualified technician or the manufacturer for assistance with replacing the control board, as working with electrical components can be dangerous if not done properly.
Posted on Feb 26, 2023
Why would check vent light go on after replacing sensor and computer
Is the dryer vent blocked with lint? If there is a restriction in air flow in the vent system, the dryer will stop. Make sure the vent path is completely clean even in the wall where the vent hose connects.
What does F1 mean on a whirlpool cabrio dryer
You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
Error code F2E1 on new Kitchen Aid KGSK901 Gas Range
This looks like the system buttons was all pushed at the same time,need to switch main power off and then on again so the board can reset it self
What does the code F2 mean in the time window of the Whirlpool Cabrio gas dryer and how do I reset the machine?
Whirlpool Cabrio & Kenmore Oasis Dryer Error Codes
  • PF--Power failure
  • AF--Restricted air flow
  • F01--Primary control failure
  • F02--Keypad/User Interface failure
  • F22--Exhaust thermistor open
  • F23--Exhaust thermistor shorted
  • F24--Inlet thermistor open
  • F25--Inlet thermistor shorted
  • F26--Motor drive system failure
  • F28--Moisture sensor open
  • F29--Moisture sensor shorted
  • F30--Restricted air flow
looks like you have a problem with the touch pad,abutton could be stuck or not responding,you can try unplugging it,get to the computer board and unplug the ribbon from the touch pad,reconnect it and try it,this sometimes resets the touch pad,if it doesn't you'll need to replace the touch pad.
F2 code for Whirlpool Cabrio Dryer - need help
it means 1 of 2 things,either a stuck key on the keypad or theres an interface mismatch on the keypad,run the diagnostics that are on a sheet of paper located under the control panel and it will tell you the exact problem
May 01, 2011 • Dryers
My whirlpool cabrio gas dryer is not heating. it is just a little over 1 year old is there a reset button for the ignitor what is your recommendation it dryed the sheets until they were damp to the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
6helpful
3answers
F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
Top Dryers Experts
Marvin
Marvin
David Shaub
