Televison & Video Logo
Technogym lower control board alarm
Hey I am trying to repair a technogym lower control board and everything is working 5v 12v 24v and 400v the fans are working too but when i plug it in and it starts up the alarm led lights up after a few sekunds and stays on. Any ideas? Kind regards Stephan
1helpful
Technogym Run 70. Equipment Blocked Contact Technical Support20
Here is there Support. Contact is at the bottom of the page.
Technogym Customer Support
Technogym https://support.technogym.com Technogym Customer Support is where you will find all the answers to your frequently asked questions, articles and useful resources to help you to get the ...
I also found this
A message stating 'the equipment is blocked' essentially means that a problem was detected that *might* be a blockage against moving of the moving parts. This commonly can be owing to two things:
1. the upper and lower assemblies (i.e the upper is the console, the lower is the electronics or boards in the lower part of the treadmill, e.g. the motor controller board and brake board) have a fault in the communication between them. This indicates first that you need to check the cable between console and lower assemblies, and also to re-seat either end, or at minimum make sure there is no breakage or crimping in that cable or wire harness, between console and lower assembly and lower boards.
or
2. the error was detected by the brake board, and one must go through the error procedure for a brake board error.
(In some models, (2) requires accessing the Low Kit Menu, to see whether there is a genuine error registered in the Low Kit Fault area of memory.)
Also
3. you might unplug it from power while it is On, and see how that works, after about 2 hours unplugged, please.
I m facing an issue to repair on technogym console
I'd be happy to help you with your software issue on your Technogym Unity3 EJ. Here are some general steps you can take to try to fix the issue:
  1. Restart the equipment: Start by powering off the Technogym Unity3 EJ and then turning it back on again. This simple step often resolves many software issues.
  2. Check for updates: Check if there are any available software updates for your Technogym Unity3 EJ. This can be done by checking the manufacturer's website or contacting their customer support.
  3. Check for connectivity: Ensure that the equipment is properly connected to the internet or network. This is important for software updates and other features that require an internet connection.
  4. Factory reset: If the issue persists, you may want to try performing a factory reset. This will erase all the data and settings on the equipment and restore it to its original state. Be sure to back up any important data before proceeding with a factory reset.
  5. Contact customer support: If none of the above steps work, it's best to contact Technogym customer support. They will be able to provide more detailed and specific guidance for your particular issue and equipment.
I hope these steps help you to resolve the software issue on your Technogym Unity3 EJ.
if u like to tip :https://paypal.me/AymanZiyat and ty
Why won't my Technogym seat lower all the way?
Please make sure there no debris stopping the seat from lowering. You can also apply a bit of cooking oil or olive oil along any metallic surfaces that the seat moves over to lower friction that might otherwise stop the seat from lowering to it's intended capability.
Thank you.
1helpful
2answers
Technogym no power to display
Assuming all the cables are ok, your display is probably dead and needs repaired. But more often than not the inverter is the problem.
If you have a way to swap it with another Technogym inverter I would try that first.
Technogym cross trainer - equipment is blocked 16
Equipment is blocked is unfortunately a common 'error' that shows up with Technogym, but it refers to a number of errors.
-Does your emergency stop swivel a lot, or is it fixed? If a cable has come off inside, that can be the cause.
-A loose cable running up the arm of the frame is the next thing to look at.
-Lastly, and most common is the motor controller has fried. It's a common thing with Technogym, and is an expensive repair. Technogym will tell you that you have to replace it, but since it's electronics it can be repaired, as long as someone knows what they are doing.
Where are you located?
Technogym Runrace displaying belt movement halted message
I've got the same problem mate - technogym say you need to have an engineer to call round but it will be expensive...
2answers
Technogym Run Excite 700 Schematics
Dear John
Please find here in attachment the schematics for the lower kit/board for the Technogym Run Excite Treadmills.
We would be very happy to help you. So, can you please tell us where do you come from? We will put you in contact with our local customer care.
Thanks
Technogym Staff
2answers
How to repair technogym 900 trradmill board
if you are talking deck belt board is LUBE first with silicones or wax. see your instruction manual. or download from www.fitness.manualsonline. com 2) if you talking about for repair control board electronic see the diagram attached. I will NOT recommend to repair anything from the board unless you are expertise in advanced electronic. replace by new ones or by some tech.God bless youb630d050-7352-402b-af89-57697605fee9.gif3541b76d-f608-4834-b80a-882c897cb96c.jpg
Technogym treadmill user manual
go to this website:
www.iconservice. com
or http:// fitness.manualsonline.com
give your model, etc, and download for free.
sincerely.
Happy New Year, G-d bless you
ernesto cuadra
managua,nicaragua c.a.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
