Has anyone found a manual for this cd/cassette boombox? Also need the power requirements for the original power supply, Thanks All!
Unfortunately, as the Spirit of St. Louis MK II (Ryan MX-211) boombox is a vintage model, it may be difficult to find a manual or specific information about its power requirements. However, you may be able to find some general information that can help.
To determine the power requirements, you can look for a label on the boombox or power supply that lists the voltage (V) and amperage (A) ratings. If the original power supply is not available, you can use a multimeter to measure the voltage and amperage required by the device.
As for finding a manual, you can try searching online auction or collector websites, as well as forums or communities dedicated to vintage audio equipment. You may also try reaching out to the manufacturer or a specialist audio repair shop to see if they have any information or resources available.
Posted on Feb 26, 2023
SOURCE: I have a wall phone,
Hello.
Try your speakerphone. If you can talk out on the speakerphone, then your receiver is bad. If you cannot talk out on your speakerphone, then your phone base is bad. Unfortunately, you may not be able to replace your phone base and would need to purchase another phone.
Hope this helps.
Posted on Jan 14, 2011
SOURCE: is it possible to download an instruction manual for spirit of st louis radio alarm clock
cant see why not do a web search imput make/model in google search machine start with makers web page
Posted on Sep 04, 2015
Are you opening by pressing manual control or by using remote control? Quite often there is a small ' pinhole aperture next to the DVD drawer - if so , use a straightend paperclip to push into the hole in order to release the drawer.
Posted on Oct 22, 2016
SOURCE: Spirit of St Louis Turntable/CD Player - Says DISC but no audio or spinning.
Get a CD Cleaning Disc. Load it, press the button and push the tray to close.
https://www.google.com/search?q=spirit+of+st+louis+turntable%2Fcd+player+disc+error+message
Posted on Dec 23, 2022
