Televison & Video Logo
Question about Sony Televison & Video
Why SONY VHS SLV-688hf won't turn on
VHS player does not power on
Aron
    Top Expert:
  • Sony Master
  • 2,496 Answers
The power supply is not working or there is a power black out or a fuse is bad or the wiring is either loose or no longer working.Or the receiver is bad.
Posted on Dec 27, 2022
Sony SLV-R1000 VHS player does not power up.Tried a different power cord
Start with checking the fuse inside the recorder itself. If that is fine, check the internal power converter for any blown capacitors.
1helpful
Need operating manual
http://www.docs.sony.com/release/SLV688HF.PDF
While trying to convert a VHS to a DVD, both are placed into the converter and I press the button indicating the process to begin conversion from the VHS tape to the DVD, but when I press the...
The Sony SLV-D300P is a DVD PLAYER and VCR. It does not record DVDs. You would have to buy a combo unit with a DVD recorder, not just a DVD player.
The record button does not work. I need to replace the record button on the unit, it is broken.
If it is one that pushes on a small switch (ie just a piece of plastic that has detached from the front panel). The best way is to use a soldering iron to melt the plastic back to the front panel. Use protective glasses when melting it, plus in a well vented room. You might need to find a scrap of plastic from somewhere, just a small piece, to reinforce it. Airfix kits have waste bits in them, or just a pen top!
Lost remote; how do you switch to Line 2 (front input lines) without the remote?
Most video's will switch to aux imputs by pressing the up & Down channel selectors.
Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
