Cameras Logo
Question about Canon Cameras
My Canon Powershot A2200 giving white screen and closing automatically?
When I opened my Canon Powershot A2200 it is giving me white screen and closing down.
ADMIN Andrew
    Top Expert:
  • Canon Master
  • 57,483 Answers
Question edited for clarity.
It sounds like the battery is flat or not holding a charge. Remove it and test the voltage with a multimeter. It should be 3.6 volts.
https://www.google.com/search?q=canon+powershot+a2200+battery
Posted on Dec 25, 2022
Why wont my canon powershot a2200 turn on after i dropped it
I think you answered your own question there. There is a chance that the battery or memory card is not seated properly after the fall so you might try removing both, let the camera sit for 15-30 seconds and reinstall the battery/card and give it a go. Otherwise, there's most likely internal damage and the camera will need to be repaired or replaced.
Canon a2200 screen
The LCD screen inverter maybe faulty. Take your camera to the Canon repairer to have the camera fixed.
I have A2200 cannon powershot camera but the flash is not working
You can Google your camera make/model and open the link to download your user manual in a PDF. I did this and picked the one below. Under the Table of Contents, pick Turning off the flash. The instructions to turn it on are there as well.
Hope this helps. Mike
CANON POWERSHOT A2200 USER MANUAL Pdf Download. www.manualslib.com > ... > Digital Camera > PowerShot A2200
View and Download Canon PowerShot A2200 user manual online. PowerShot A2200 Digital Camera. PowerShot A2200 Digital Camera pdf manual download.
1helpful
I have the canon powershot a2200 and the screen is just black as well as my pictures
okay 1 of 2 things is wrong i think A) the lens or that area is broken some where B) the screen is broken what you need to do is send it to canon so they can tell you what the problem is
if the screens broken buy one off the internet open the camera using a eyeglass screw driver or you will strip the screws look how the screen is connector flip the switch and take out and replace you screen the video that i have linked isn't your camera but the assembly and disassembly should be the same and so the screen changing i cant help you if its problem A) my only advice buy a new camera if cost effective or get it repaired
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
