Question about Samsung Refrigerators
Ice maker doesnt work and freezer temp is much higher than set
The control panel on your Samsung RF4287HARS refrigerator can potentially affect the temperature in the freezer and the operation of the ice maker. If the control panel is not functioning properly, it can cause the freezer temperature to be higher than the set temperature, and it can also prevent the ice maker from working. To troubleshoot the problem, you can try the following steps: Check the control panel settings: Make sure the control panel is set to the correct temperature for the freezer and that the ice maker is turned on. Check the control panel wiring: Make sure all the wiring for the control panel is securely connected and not damaged. Check for any frayed or damaged wires, and repair or replace them as needed. Check the control panel: If the wiring is in good condition, the problem may be with the control panel itself. You can try resetting the control panel by unplugging the refrigerator and waiting a few minutes before plugging it back in.
Posted on Dec 24, 2022
