Exercise & Fitness Logo
Z Patel Posted on Dec 24, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Reebok Jet 200 is stuck at an incline
My reebok jet 200 tripped a fuse which burnt out the motor for the belt. At the time it was at an incline and after replacing the belt motor the incline didn't go down. The incline can still go further up, but the 0 position is not really at 0. Any idea how to fix the incline or recalibrate it
Mymp Mympop
Level 2:
Novelist:
  • Expert 172 Answers
  • Posted on Dec 24, 2022
Mymp Mympop
Expert
Level 2:
Novelist:
Answers
172
Questions
0
Helped
94045
Points
441
If your Reebok Jet 200 treadmill is stuck at an incline and you are unable to lower the incline to the 0 position, there are a few things you can try to fix the problem:
  1. Check the incline motor and make sure that it is properly installed and functioning. If the motor is damaged or not functioning properly, it may be causing the incline to remain stuck.
  2. Check the incline control board and make sure that it is properly connected to the incline motor and other treadmill components. If the control board is damaged or not functioning properly, it may be causing the incline to remain stuck.
  3. Check the incline cable and make sure that it is not frayed or damaged. If the cable is damaged, it may be causing the incline to remain stuck.
  4. Check the treadmill's belt and make sure that it is properly aligned and tightened. If the belt is misaligned or loose, it may be causing the incline to remain stuck.
  5. Check the treadmill's power supply and make sure that it is properly connected and functioning. If the power supply is not functioning properly, it may be causing the incline to remain stuck.
If you have tried all of these steps and are still having issues with the incline on your Reebok Jet 200 treadmill remaining stuck, you may want to consult a professional for further assistance. A treadmill repair technician will be able to diagnose the problem and recommend the best course of action to fix it.
REEBOK GT30 TREADMILL. It has ERROR E2. What does this mean please?
E2 Error usually indicates that the treadmill is overloaded and applies to various models like TR150, TRX1000 and TR 200. To fix this problem, check if your treadmill motor is overheating. Signs of an overheated motor include; grinding noise, motor produces a burning smell and inconsistent operation speeds.
Treadmill repair : r/fixit
Reddit · r/fixit 3 comments · 4 years ago Hi i have a reebok one gt30 treadmill bought in 2016. Recently at ... Start googling error codes and find out what E2 means. Upvote 2
Which part of my broken treadmill should I try replacing? - Reddit
Apr 18, 2020
Urevo 2-in-1 giving e10 error message- did you encounter this ...
Oct 10, 2022
Need help with Sole F63 treadmill error code - Reddit
Nov 21, 2022
More results from www.reddit.com
Reebok jet 300 treadmill e02 error - motor output dc is 11v on ...
All About Circuits https://forum.allaboutcircuits.com > threads > reebok-j...
Jan 9, 2023 - It seems to me to be a problem in the circuit that gives feedback to the processor about the voltage in the motor, error02 and does not arm the ...
Missing: GT30 ‎' Show results with: GT30
Treadmill Support - Reebok Fitness
reebokfitness.info https://www.reebokfitness.info > treadmill-support
View user manuals, assembly guides, instruction books, and technical support videos for all Reebok treadmills, including how to reduce static shock.
Reebok 8000ES stuck incline position will not decline.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj79pDHxZSCAxV_AHkGHbhiDxkQFnoECBsQAQ&url=https%3A%2F%2Fwww.justanswer.com%2Ffitness-equipment%2Fgdah0-reebok-8000es-treadmill-incline-keeps-going.html&usg=AOvVaw0mEH-BLg44uwLpy6jJGb3K&opi=89978449
I have a Reebok ZR9 Treadmikk stuck in the incline position and showing error 1 whwn switched on. I have checked for lose connections Please can you help.
Check the incline motor: If resetting the treadmill doesn't work, it's possible that the incline motor is faulty and needs to be replaced.
My Reebok 9500 ES Treadmill is stuck at it's max incline.
  1. Check the belt: Make sure the belt is properly aligned and tensioned, as a misaligned or loose belt could cause the incline to get stuck.
  2. Check the incline motor: If the incline motor is not functioning properly, it could be preventing the incline from moving. You may need to have the motor inspected or replaced.
  3. Check the incline sensors: If the incline sensors are not functioning properly, they could be preventing the incline from moving. You may need to have the sensors inspected or replaced.
  4. Check the control board: If the control board is not functioning properly, it could be preventing the incline from moving. You may need to have the control board inspected or replaced.
If these steps do no
2answers
Why does my Reebok Jet Treadmill slow down
if the machine slows down when you get on it, there might be a motor issue or problem with a bad circuit within the treadmill.
Thank you.
Will a reebok rodger black motor drive belt fit a reebok 2.2edge treadmill
Dear Sir:
Most of the time, can be fit in reebok 22.edge treadmill.Otherwise you can adjust the main motor and puller for to fit.
sincerely. God bless youm
ernesto cuadra
managua, nicaragua. c.a
4helpful
Hello - when I turn on my reebok treadmill, the only buttons that work are start and incline (incline works most of the time). All of the other buttons do not work. Its a Reebok Vista RBTL13305 model...I...
Let me know if you find a solution. I am having the same problem and cant figure it out. It turns on and will start but none of the other buttons work. Its so frustrating.
1helpful
2answers
We purchased a reebok edge 2.2 treadmill about 3 weeks ago, a couple of nights ago the electic trip out whilst using the treadmill and since then the belt hasn't moved the display still works and counts...
i had the same problem, i beleive its the motor it may have burnt out.
only had it less than 4 weeks, argos sent a replacement treadmill and took the broken one away.
The belt won't move and the incline is stuck. display isn't working properly either
reebok 8000es incline keeps going up and down and will not stop or go into any other mode
3helpful
2answers
Where can i get a reebok TR3 treadmill user manual
Updated linkhttp://www.iconservice.com/CustomerService/manualsProductManuals.do?model=RETL1600&modelName=REEBOK+RT1000+TREADMILL&version=1&company=11&language=
Top Reebok Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
