Expert
- Posted on Jan 13, 2023
Re: Kortek MagicSing YK5000 not connecting to LG Smart TV...
It sounds like you are experiencing an issue with your Kortek MagicSing YK5000 not connecting to your LG Smart TV via HDMI. Here are a few suggestions for troubleshooting the issue:
- Check the HDMI cable: Make sure that the HDMI cable is securely plugged into both the Kortek MagicSing YK5000 and the LG Smart TV. Also, check the cable for any damage, such as frayed wires or a broken plug.
- Check the HDMI input: Make sure that the HDMI input on your LG Smart TV is selected and that the TV is set to the correct input source.
- Check the TV settings: Make sure that the TV's settings are configured to accept an HDMI input from the Kortek MagicSing YK5000.
- Check the YPbPr adaptor input: Make sure that the adaptor is securely plugged into both the Kortek MagicSing YK5000 and the LG Smart TV. Also, check that the adaptor is not malfunctioning.
- Check the TV firmware: Check if there's any firmware updates available for your TV and make sure that it's up to date.
- Contact the manufacturer: If none of the above solutions work, it may be necessary to contact the manufacturer of the Kortek
Thanks for responding, Arty. All three suggestions are tested - everything is fine.
Karaoke works properly with original TV directly. So Karoake m/c + LG Smart TV HDMI ports and cable are all tested individually - all work well.
Is there any other adaptor/converter I should try? Thanks.
