Re: Sunbeam® Cool Mist Humidifier SCM1100 is not...
Question edited for a lot more clarity.
There is virtually nothing to these machine, just a drip valve, a wick and a fan. Is the filter older than a month old? If there is water in the base, it is working.
Find your filter for your Sunbeam® humidifier to keep the air in your house comfortable, water treatment tablets offer a light scent to the mist from your humidifier.
The Sunbeam SUL2512 Humidifier has three parts. From the top down:
Water tank
mist collar
Base unit
If the cap of the water tank (which contains a float valve) does not seal you may get excessive flow into the base unit which provides a working reservoir.
The base unit contains all the electronics including the cool mist transducer. This is a silver disk with a black silicone seal surrounding it. This is the only other place a leak can develop.
you may need to empty the water that went into the base and retry putting the top tank back on sometimes too much water gets into the bottom and it wont put out vapor. at least mine does that and it is an ionic cool mist humidifier which means uses no filter
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
from all the information that i have come across. the unit is a cool mist. the vapor won't be apparent for the coolmist. now if it was a warm mist there is something internal that isn't making it cause any vapor. but if you done all the normal troubleshooting and nothing still and it has a filter it will more likely be a cool mist. warm mists don't have filters
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
