Question about Pioneer Audio Players & Recorders
How do I hook up Kenwood gge 7030 to my pioneer sx217?
I guess as I got older I have gotten dumber I have a Kenwood GE 7030 EQ to hook up to a pioneer SX 217 receiver ,it's very plain and simple but I'm having problems getting it to work all my equipment is good and has the basics jacks on the back of pioneer tape record out and in just as the EQ in and out display works but I have no sound and I've tried everything can you help please?
Posted by Kevin Greable on
Mymp Mympop
    Novelist:
  • 172 Answers
To connect a Kenwood GE 7030 equalizer to a Pioneer SX-217 receiver, you will need to use the tape record out and in jacks on the back of the receiver. Here is a general outline of the steps you can follow to set up the connection:
Locate the tape record out and in jacks on the back of the receiver. These are typically labeled "TAPE MONITOR OUT" and "TAPE MONITOR IN."
Locate the tape in and out jacks on the back of the equalizer. These are typically labeled "TAPE IN" and "TAPE OUT."
Use a pair of RCA cables to connect the tape out jack on the receiver to the tape in jack on the equalizer.
Use another pair of RCA cables to connect the tape out jack on the equalizer to the tape in jack on the receiver.
Turn on the equalizer and set the volume and tone controls to your desired settings.
Turn on the receiver and select the tape monitor function. You should now be able to hear sound through the speakers.
If you are still having trouble getting the equalizer to work, it is possible that there is an issue with the cables or with one of the components. You may want to try using different cables or checking for any visible signs of damage on the components. If you are still having trouble, it may be helpful to consult the user manual for the receiver or the equalizer or to seek the assistance of a professional audio technician.
Posted on Dec 24, 2022
Testimonial: "Yes I have hooked up exactly as so ,display works but no sound from eq"
  • Mymp Mympop
    Mymp Mympop Dec 24, 2022
    If you have already set up the connection as described above and are still having trouble getting the equalizer to work, there may be an issue with the cables or with one of the components. You may want to try using different cables or checking for any visible signs of damage on the components.
  • Mymp Mympop
    There are a few things you can try to troubleshoot this issue:
    Check the volume levels on the equalizer and the amplifier. Make sure that both are turned up and that the volume control on the amplifier is set to the correct input for the equalizer.
    Check the connections between the equalizer and the amplifier. Make sure that all the cables are securely plugged in and that there are no loose connections.
    Check the settings on the equalizer. Some equalizers have different audio processing modes that can affect the output sound. Make sure that the equalizer is set to the correct mode for your system.
    Check the settings on the amplifier. Some amplifiers have built-in equalization settings that can affect the output sound. Make sure that the amplifier is set to the correct settings for your system.
    If none of these suggestions resolve the issue, it is possible that there is a problem with the equalizer or the amplifier. You may need to have the equipment checked by a professional audio technician or bring it to a repair shop.
How do I hook up Pioneer GR 470 EQ to my Sherwood RX 4105 receiver? I have Pioneer M403 's changer hooked up already
Normally you would hook up the EQ to the tape recorder in and outs of the Sherwood. This way if it has a tape monitor button, you can press that and all the functions would pass into the EQ.
1helpful
Hook up kenwood ge-1100
2 stereo rca cables tape out to line in on eq, line out from eq to tape in on receiver. press tape monitor button to use eq, turn off tape monitor for direct. some receivers also have a dedicated I/o for eq, you just need to remove the jumpers and install in that loop (out to in on eq out from eq to in on rcvr}
GE 7030 sound became weak and distorted . Now all lights are on but no sound
Stesso problema,lo accendo e si illumina il display,accendo tape 2 sull amplificatore e non va,oppure si sente un suono molto disturbato.dovrebbe essere qualcosa di semplice da cambiare,ma cosa??
1helpful
Wire Kenwood GE 7030 equilizer to onkyo tx sr504 receiver
The manuals explain it.
http://www.retrevo.com/support/Kenwood-GE-7030-manual/id/479dj189/t/2/
http://www.retrevo.com/support/Onkyo-TX-SR504-Receivers-manual/id/365ag215/t/2/
For all practical purposes an EQ or any analog audio processor connects exactly like a Tape Deck - into any RCA pairing that has both an OUT and an IN and can be selected to be in or out of the audio path.
However, on this and just about any modern digital-capable AV Receiver, activation of any external loop that would connect a processor or tape deck would automatically DISable any digital audio sources. The effects of the processor, therefore, can only be used with analog stereo sources. It WILL affect the sound going to all speakers if you use the various Digital Sound Porcessing modes as the extra channels are derived from the stereo channels anyway.
2answers
Kenwood GE 7030 equalizer; no control
if you have bypass button in your equalizer check if not depressed.
2helpful
2answers
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
I have Pioneer Amplifier with Phono Inputs. Also I have an Akai stereo Equalizer. I want to connect my Turntable to the pioneer amplifier through Akai stereo Equalizer to have a better sound quality. Is it...
hook the turntable "directly" up to the "phono" inputs. if it sounds normal this way, and not loud and distorted, then you have to plug the turntable up that way, directly to the reciever's phono input.
you can hook the eq up through the "tape in/out" jacks.
take the tape record out jacks, and hook them up to the input of the eq, and take the tape play input jacks and hook them up to the output of the eq. then, to use toe eq, select whatever input you want eq'ed, while also selecting "tape monitor"
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
Open Questions:
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
David Shaub
Steve
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
