My invacare bed head section won't go up to 90degrees and I need it too. Is that a possibility???
I have trouble getting out of bed with my disability. Solution could be if the head section could go a bit higher angle like 90 degrees. It goes about to 70 degrees now. Is there any way I can get it to go to 90 degree??
It is possible that the head section of your Invacare bed is not able to go up to a 90 degree angle due to a mechanical issue or a limitation in the design of the bed. You should contact Invacare or a medical equipment repair professional to have the bed inspected to determine the cause of the issue and if it can be resolved. If the bed cannot be adjusted to the desired angle, you may need to consider purchasing a different bed that better meets your needs.
It is possible that the head section of your Invacare bed is not able to raise to a 90-degree angle due to a mechanical issue with the bed. It could be due to a problem with the motor or gears that control the movement of the head section, or it could be due to an issue with the electrical components that power the bed.
You should check the following things:
Check the bed's remote control to ensure that it is functioning properly.
Make sure that the bed's power cord is securely plugged into the outlet and that the outlet is working properly.
Check the bed's battery level, if the bed has a battery backup.
Make sure that the bed is not locked in place or that the manual lock is not engaged.
Check that all the bed's connections are secure, and all the bed's cables are properly plugged in.
If none of these solutions resolve the issue, it may be necessary to contact the manufacturer or a healthcare equipment repair service for further assistance.
renew all bolts for cyl.head mains and big ends
cyl head stage1 35nm stage2 60nm stage3 +90degrees
mains stage1 65nm stage2 +90degrees
big end stage1 30nm stage2 +90degrees
Use the (M) Auto-Firm Button. Press the Auto-Firm Button to engage auto firm. The Mattress will become firm for nursing procedures. An indicator lights to notify the bed is in Auto-Firm mode. A timer will cancel auto firm in 30 Minutes. Should the nurse be called away, an unattended patient will not be left on a firm surface.
Set the patient weight with the Weight selection buttons (G).
Press the "Center" static Turning Mode button (I).
Place the patient on the bed.
Center the patient on the bed from side-to-side and head-to-foot.
Use a regular pillow under the head for comfort and to prevent the head from rolling excessively.
Raise side rails.
Press the desired Turning Mode button (O).
Press the Full Turn Range button (J).
Set the Turn Interval time with the up/down buttons (L).
If the patient feels the bed is too soft/hard press the up/down Comfort Range buttons accordingly (H).
Patty,
Thank you for your e-mail reply for clarification.
We can try to locate your part by description in a diagram.
A very popular full electric bed was made by Invacare and also Hard Manufacturing.
Let's try going to Invacare.com. Click on the following drop down menus.
Click on the tab, parts catalog:
parts category beds and TSS
Homecare beds manual, semi electric, full electric Careguard by Invacare
Bed ends full electric 5301 Low
If this looks like your assembly we are set and I can help you further.
If not we can call a company in New York called Hard Manufacturing.
If these two options don't work you may have to bring the bed end down to a local dealer and see if they can help. Please reply and I will help you further.
By the way, the manufacturer tag may be on or near the control junction box where the motors and hand control plugs in, possibly underneath on the frame.
