Computers & Internet Logo
Question about Sony Computers & Internet
Sony STR-KS360 5.1 Surround Sound System: blinking standby light.
The question appears on your site, however there is no answer found.
Posted by Bruno Monfils on
ADMIN Andrew
    Top Expert:
  • Sony Master
  • 57,349 Answers
It is a Sony and they normally need repairing at a service centre. You can't repair them at home. Try a Power Reset and there is some other help in this link.
https://www.google.com/search?q=Sony+STR-KS360+5.1+Surround+Sound+System%3A+blinking+standby+light
Posted on Dec 22, 2022
Sony BRAVIA Fails to fully Power ON. TV shuts off when backlight should kick in, after logo lights and fades. 'standby' blinks 6 times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
2answers
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Sony wega tv kp 51ws520 keeps turning off after the standby red light blinks 10x's
problem with str ic need replacement has an internal short need a tech to do it
Sony STR-DE475 - no surround sound
Thanks for all the info. It appears that the Receiver requires service as there is no test tone also. However, please clean the speaker cables and speaker jacks and reconnect. Also, try the steps mentioned in the link below.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C216020&fes=true&mdl=STRDE475
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
2answers
Need instruction on how to set up to surround sound.
Go to www.sonystyle.com click on "support" Type in your model # and you will get more information the you could ever need on that receiver! Including the manual. Hope this helps!
1helpful
No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
1helpful
Sony STR de845, 5.1 Surround does not work. 3.2 is indicated o
3.2 IS the "5.1" mode for this receiver. 3.2 is indicating that you have 3 front channels and 2 rear channels. The ".1" is applied to all the speakers (LFE). If you read the manual on page 37, you'll see that "3.2" is displayed with either "Dolby Digital 3.2" or "DTS 3.2". The little icons of the speakers in the display window will show you which channels are active. The bottom line is as long as you see the blue light, it's decoding multi-channel discreet surround sound (at least 5.1).
3helpful
2answers
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Top Sony Computers & Internet Experts
Steve Nordquist
Steve Nordquist
Marvin
Marvin
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
