Contributor
- Posted on Dec 21, 2022
Re: smeg gas hob, 2 burners have very low flame
If two burners on your Smeg SR275XGH2 gas hob have a very low flame, it may indicate a problem with the burners or the gas supply. Here are some steps you can try to fix the problem:
- Check the gas supply: Make sure that the gas supply to the hob is properly connected and turned on. If the gas supply is off or disconnected, the burners may not function properly.
- Check the burners: Check the burners for any visible damage or blockages that may be causing the low flame. Make sure the burners are clean and free of any debris or foreign objects.
- Check the gas pressure: Make sure that the gas pressure to the hob is set correctly. If the gas pressure is too low, the burners may not function properly.
- Check the connection: Make sure that the connection between the hob and the gas supply is secure and not damaged. If the connection is damaged, it may cause the burners to function improperly.
- Contact technical support: If the above steps do not help, you may need to contact Smeg or a technical support team for further assistance. They will be able to diagnose the problem and provide you with the necessary support.
It is also a good idea to check the documentation or manual that came with the hob for any troubleshooting tips or recommendations.
