Computers & Internet Logo
Question about Dell Computers & Internet
Dell OptiPlex 780 with Windows 7 shut down
Isma Ismal
    Problem Solver:
  • 5 Answers
It sounds like you are experiencing an issue with your Dell OptiPlex 780 computer where it is shutting down unexpectedly. There are a few potential causes for this issue, and several potential solutions that you can try to resolve it.
Here are a few steps you can try:
  1. Check for updates: Make sure that your computer is up to date with the latest Windows updates. Sometimes, these updates can fix issues with the operating system that may be causing your computer to shut down unexpectedly.
  2. Check for hardware issues: Make sure that all of your computer's hardware is properly installed and functioning correctly. If you have recently installed any new hardware, it's possible that it could be causing the issue.
  3. Check for malware: Run a malware scan to make sure that your computer is not infected with any malicious software. If you find any malware, remove it as it could be causing the shutdown issue.
  4. Check for overheating: Make sure that your computer's internal temperature is not too high. If it is, it could be causing the shutdown issue. You can try cleaning the inside of your computer and making sure that the air vents are not blocked to help keep the temperature down.
  5. Check the power supply: Make sure that your computer is receiving a stable power supply. If it's not, it could be causing the shutdown issue.
If none of these steps help to resolve the issue, you may want to try contacting Dell for further assistance. They may be able to help you diagnose and fix the problem.
Posted on Dec 18, 2022
Do i have to take away the service mode jumper optiplex 780
With Windows Vista, 7 and 8 the computer is suppose to give an alert when installing a new program
Dell OptiPlex 780 with Windows 7 does not play my cd's or dvd's and is missing from device manager
Sounds like a problem of non-detection by the system. If the drive is missing from My Computer then it definitely is a non-detection issue. Try using this file (it's an exe when unzipped) and only required double-clicking.
http://www.geekstogo.com/forum/files/file/8-cdgone/
Windows has recovred from an unexpected shut down
This message was displayed only because the last time system wasnt shut down properly don't worry and continue to work
Problem on Dell OptiPlex 780 Desktop
You are going to need to start your computer in safe mode and find the XP drivers that will work for your motherboard manually from the web (Assuming that there are any created for XP for that board)..
That blue screen you keep getting is because you don't have the correct driver loaded for something on the motherboard that it needs to boot correctly and your XP install couldn't find it on the web to install automatically.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking".
Now start looking for your drivers here:
http://www.dell.com/support/drivers/us/en/19/Product/optiplex-780
Dell optiplex 780 i wanted to change from windows 7 to xp blue screen appears how to fix
You are going to need to start your computer in safe mode and find the XP drivers that will work for your motherboard manually from the web (Assuming that there are any created for XP for that board). That blue screen you keep getting is because you don't have the correct driver loaded for something on the motherboard that it needs to boot correctly and your XP install couldn't find it on the web to install automatically.
4helpful
I have dell optiplex 780, the built-in speaker is not working with windows 7 32 bit. but if i will used windows xp i have no problem, plss i need your help i want my built-in speaker working with windows 7...
try right clicking on your volume icon the speaker in your tray the select playback devices and see if its selected or listed if its there and no got a check mark check it and you should be good ..if it isn't there try updating if still no go then the sound card simply wont work for windows
don't forget to give testimonial and the votes 4 thumbs up if I helped.
Dell optiplex 780 shutdown automaticaly
The desktop could be overheating and shutting down.
To fix this problem, please click on this link :-
Clive
Clive
Steve Sweetleaf
Steve Sweetleaf
