This unit is about 10 years old and has worked fine until recently. Now, when I turn the heat on the fan starts and the heating element gets hot. After a few minutes the heater element turns off but the fan continues to run. In a few more minutes the heat comes back on, heats for a few minutes and turns off again. The unit will repeat this cycle until the desired temperature set on the thermostat is reached and then it will stop as normal. My thermostat is an Amana PHWT-A150H. Thanks for any help!
One of the reasons this could happen is the heat sensing limit switch area has a lot of dirt, which could make it appear that the desired temperature has been achieved. So cleaning/air-blow that section and also cleaning the inside/fan-blower area might be helpful. There is a outside thermistor, which cn be fauluty as well. I have seen a few of these instance for the above heating issue. Hope this helps. Good luck
I'm not familiar with your specific unit but ..sounds like an electronic gas value has gone bad or has a bad connection when that happened to my friend it wasn't that expensive to have it fixed .. BYW it acted like this for a while then stopped working completely
Testimonial: "Thanks for trying, but this unit is an all electric unit. If you ever stay at a Hampton or Holiday Inn, this is the unit under the window."
