Question about Akai PT4298HD Rear Projection Television
There is (coloured)'ghosting' - seems to be more on one side than the other.
Posted by sweatherell4 on
Edward
  • Akai Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,PioneerThere is (coloured)'ghosting' - seems to be more - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fThere is (coloured)'ghosting' - seems to be more - bb0cf99.png data-src="/uploads/images/bb0cf99.png" alt="bb0cf99.png" class="h_mi" /> http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
Why is there ghost printing/shadows on my xerox workcentre 7335?
Suresh,
You don't say if the ghost is a particular colour, by ghost I suspect you mean similar to a drop shadow.
Firstly run off an internal test print, one of each colour if the grid lines are fine and showing no signs of shadow then your problem is not an internal problem. Don't send a C,M,Y,K test print from your computer, you can't eliminate colours that way.
If you can pin the problem down to one colour it could be a particular drum unit. Investigate from there.
Good Luck.
May 03, 2015 | Xerox Workcentre 7335 All-in-one Laser...
Ghosting
degousse (demagnitize), or your colour drivers and crapping out. Or you may have something magnetic close by. did you just move your set?
Jun 10, 2014 | JVC Televison & Video
Hp 5550 patchy print
Most of the cases fuser assembly or supplies are causes of ghost image. If image is not properly transferring on media causes transfer roller or ETB.
Do this small exercise: Give print command, wait till paper grabs, once paper entered in cartridge area, power it off, open top & front cover, remove paper and see the print quality.Observed any ghost image what you observed? No ghost image? then problem with fuser assembly..
1.Remove fuser assembly, check any toner particles deposited on surface of fuser transfer roller or heater roller.. if found clean carefully with good cotton cloth while fuser having certain temperature,pl avoid metal & sharp objects to clean..
2. Clean paper path roller(You can observe the rollers to push the paper to reach the destination)
I hope this exercise will resolves the issue..
Jul 26, 2012 | HP Color LaserJet 5550hdn Printer
My LG rear projection TV RE40NZ60RB colour is ghosting with three colours separating. Colour converging does not rectify
There is a problem with the convergence circuit. It can be as simple as poor solder connections at the pins of the convergence IC or a defective IC. If you can solder, you can fix this yourself. Please confirm the model number of hte set and I'll provide the part numbers etc. required to resolve this.
Thanks,
Dan
Aug 20, 2009 | Televison & Video
Epson 1290 prints a ghost image in cyan or magenta
I like this one! No don't have a solution but....interesting Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Apr 23, 2009 | Epson Stylus Photo 1290 InkJet Printer
Ghost like shadows
It seems your TV Samsung HCM4215W has problem in convergence board and need to be replaced.
You can get that board from Parts Store on $76
If you have bit electronics knowledge and know how about tv repair, you can replace it by yourself or get help of local tv tech person.
Oct 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Ghosting on LCD TV
get a big heavy brick and throw it at the screen this fixed mine
in no time and got a sony instead
Apr 08, 2008 | Televison & Video
Tri coloured ghosting
maybe...it might need service mode aligning be a tech
Jan 02, 2008 | Televison & Video
Akai PT4298HD Rear Projection Television Logo
48 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
