Expert
- Posted on Dec 26, 2022
Re: MEMBERS'S MARK MICRO CUT/12 PULSES WHEN SHRERRING....
If your Member's Mark micro cut shredder is experiencing a problem where it is making 12 pulses when shredding and works good in reverse, it is possible that there is an issue with the shredder's motor or transmission. Here are a few things you can try to troubleshoot the problem:
- Check the shredder's capacity: Make sure the shredder is not overloaded and that you are using it within its capacity. Overloading the shredder can cause issues with the motor and transmission.
- Check for debris: Look for any debris that may be stuck in the shredder's mechanism. Debris can interfere with the movement of the shredder's components and cause problems.
- Check for other issues: If the shredder is not overloaded and there is no visible debris, it is possible that there is another issue causing the problem. You may need to have the shredder serviced by a professional to diagnose and fix the issue.
I hope this information is helpful. If you have any further questions or need additional assistance, please don't hesitate to ask.
