Heating & Cooling Logo
Vince O Posted on Dec 12, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to access anchor points on a Pyrox Firestar HE324M inbuilt gas heater?
My heater has fallen forward as the two anchor points/plastic wall plugs have come out but I'm trying to figure out how to access them? Or does anyone know where I might get install manual for this model heater?
Bashar Telesi (TerraceDS)
Level 2:
Novelist:
  • Expert 200 Answers
  • Posted on Jan 06, 2023
Expert
Level 2:
Novelist:
Answers
200
Questions
0
Helped
40149
Points
498
To access the anchor points on a Pyrox Firestar HE324M inbuilt gas heater, you will need to remove the front
  1. Turn off the gas supply to the heater and disconnect the power supply.
  2. Carefully remove any decorative trim or surrounds that may be covering the front panel.
  3. Locate the screws or clips that are holding the front panel in place. These may be located at the top and bottom of the panel or along the sides.
  4. Using a screwdriver or a suitable tool, loosen and remove the screws or clips to release the front panel.
  5. Carefully lift the front panel off the heater, being careful not to damage any of the internal components.
  6. The anchor points should now be visible. They are typically located at the corners of the heater, near the bottom.
1helpful
How do I hang an object using drywall anchors?
hi there.
Sink A Self-Drilling (Threaded) Anchor
  1. Mark your hanging point with a pencil.
  2. Tap the pointed tip of the anchor into the wall with a hammer.
  3. Once the tip is in the drywall, with a screwdriver, screw the anchor in until it's flush to the wall.
Fix-It Friday: Anchors Aweigh! How To Put Anchors Into Walls
womenyoushouldknow.net/fix-it-friday-anchors-aweigh-how-to-put-anchors-into-walls/
How to Install Drywall Anchors to Hang Heavy Stuff on Your Walls
How do hang an object using drywall anchors Google Search
Nov 28, 2017 • Drywall
2answers
Pyrox wall heater turns off after an hour running and Er 12 is on there
Seems like you need to call the Pyrox to find out. If you need more questions for your AC Repair needs, check us out online.
Does Vulcan Pyrox gas wall furnace have a filter? It seems to cycle on and off too often and the gas seems too high. Also it makes a bang when reigniting. How can I turn the gas down inside it?
get it serviced by a licenced gas fitter / plumber. Should be serviced every two years. Don't risk your life via carbon Monoxide poisoning get a licenced gas fitter /plumber to assess the unit.
Trying to locate replacement parts for my gas wall heater
http://www.enviro-friendly.com/bonaire-gas-wall-furnaces.shtml
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
3helpful
I have a model HE424M 33Mj/h gas Pyrox Firestar gas heater. I have just cleaned it and now it does not start. The pilot light is ok as is the spark but as soon as I let go of the centre button tha whole...
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out.
8helpful
Pyrox natural gas heater not functioning properly
Clean the burners out with air pressure,like from a air tank,and a blow gun,then clean the pilot light orifice(this is where the pilot light is)if this does not help,replace the thermocouple ,it will be the problem,if this was at all helpful,please rate,thank you.
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
1helpful
Error f1 3
What did you find out about this code? did you contact Pyrox? ask them the code meaning. if it is a need for a tech then thats the way to go they should be able to advise you.
Top Heating & Cooling Experts
Paul Carew
john h
