Televison & Video Logo
A
Anonymous Posted on Dec 10, 2022
How do you get your dish remote back In sat mode after you power scan
Michael Crain
Level 2:
Novelist:
  • Expert 76 Answers
  • Posted on Dec 10, 2022
Michael Crain
Expert
Level 2:
Novelist:
Answers
76
Questions
0
Helped
17205
Points
203
To get your dish remote back into sat mode after a power scan, you will need to re-pair the remote with the receiver. Here are the steps to follow:
  1. Turn on the receiver and make sure it is in sat mode.
  2. Press and hold the SAT button on the remote for at least three seconds, until the mode lights on the remote turn on.
  3. Press the pound (#) button on the remote, then press the SAT button again.
  4. Use the remote to select the receiver you want to pair with, then press the pound (#) button again.
  5. The remote should now be paired with the receiver and in sat mode. You should be able to use it to control your dish equipment as usual.
If you have any trouble re-pairing the remote with the receiver, you can try pressing the reset button on the receiver and repeating the steps above. If you are still unable to pair the remote, you may need to contact dish customer support for assistance.
I am having issues hooking up a D-VR600KU to a dish network box. It asks for a manufacturers code and this is not in the manual. Does anyone have a solution to this issue? It is currently connected to both...
We would be happy to help. We currently do not have any codes specifically for your Toshiba D-VR600, we would recommend performing a power scan. If there is a code that is compatible with your TV the power scan will find it.
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate, then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
After doing the power scan please remember to put the remote back into SAT mode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
The tv is jammed. Remote is fine but have pressed the wrong button
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
Could not program dish network remote to combo emerson tv
We would be happy to help. We currently do not have anycodes specifically for your Emerson TV/DVD combo unit, but we would recommend performing apower scan. If there is a code that is compatible with your TV, the power scanwill find it. Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Step 3:
Press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, the TV will turnoff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SAT mode.Thanks so much for being a valued DISH Network customer!
Phillip Chang
3helpful
Dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Need code to use dish network 3.0 IR remote with Magnavox h2160mw
I have dish network and a new rca tv with dvd the
My dish network remote stop working
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux mode. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Code For A Dish Network remote
Need three digit code to access DISH network remote for a Haier HL19R1a
We would be happy to help. We currently do not have anycodes specifically for your Haier TV. We would recommend performing apower scan. If there is a code that is compatible with your TV the power scanwill find it. Power scan instructions:
Step 1:
Step 2:
Step 3:
Press the Up button once per second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Phillip Chang
Looking for dish network codes for the Philips SRU3003 remote...
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
