If you entered the 42CC 18" it is a PP4218(AV, AVHD or AVL) Gas Saw Type 2. The letters after the 18 correspond to the type of chain tensioning system. Poulan.com http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html The dash number of your serial number is the type. Match the "Handle, Chassis and Bar Assembly" with your saw to complete the IPL. An OM and less detailed IPL for your saw can be found here: CurrentModels http://www.poulanpro.com/node4043.aspx Type just the model numbers (choose the suffix after the list is provided).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH Lou
What you request to the best of my knowledge does not exist. You may find this helpful. Had you provided a model and serial number it would have been more helpful.
Typical fuel system and couple of suggestions: http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL for you saw can be found here: The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations. Poulan.com http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html The dash number of your serial number is the type.
If I can be of further assistance you can reply below. I hope you found this most helpful.
Lou
Results for a Poulan 4018WT Type 2 (WildThing)
That is excessive, make them repair it. Your saw is warranted for 1 year.
The IPL lists no oiler adjustment and the Operator's Manual doesn't mention any oiler adjustment. Manual http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006-P4018WT-952802029.pdf IPL http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008-P4018-545103414-952802151.pdf If you using any Bar Oil (30 weight with stuff added to make adhere to your bar and chain) and not a light weight motor oil I recommend you contact Poulan and make them repair it. Anything you attempt may void your warranty, do nothing without an official OkeyDokey. Get names, dates, and times in an e-mail for any official OkeyDokeys and save a copy them somewhere a computer crash won't wipe them out.
Contact Poulan here: Poulan.com The dash number of your serial number is the type. http://www.poulanpro.com/node4033.aspx or telephone during normal business hours EST here: Handheld (Chainsaws, Trimmers, Blowers, Edgers) 1.800.554.6723 Have your chainsaw within easy reach, they will want your serial number.
Call your local Power Equipment Dealers and ask if any of them deal with OREGON replacement parts.
OREGON makes clutch drum, chain and bar combinations in the thousands!
NOTE: Along with clutch drum and chain replacement, your bar will need to be changed also, as the sprocket-tip in the nose of the bar will be a different pitch.
