If nothing's broken, you can usually apply and hold pressure in the direction you want to the switch or ring, depending on which model you have, and lightly press the trigger to get it to move.
Brand NEW battery for MILWAUKEE M18. Quick charge with automatic constant current control prevents battery from overcharging, short circuit, and electric shock. Perfect fit for your power tool battery!
The only reason a battery powered device slows down is that it's not getting the appropriate voltage from the battery. Your m18 has a lithium-ion battery that when topped off, and for what should be a good long work-period, deliver 18vdc to the motor. Unfortunately, some of the earlier m18 batteries have had some issues and are not fully charging. Some of this is due to improper charging, over heating, storage problems and physical damage.
Milwaukee utilizes a "smart battery" Digital Management System to monitor the "draw" on the battery to keep the user from frying the motor or overtaxing the battery. How hard to you use the tools...perhaps you should trade the stock compact versions for the XC (extra capacity) versions.
You don't say how long you've had these tools, but if you'll go back to the retailer you bought them from, you may be able to get replacement batteries there. Otherwise, check out the Milwaukee website. I think they came out with M18 XC "RED LITHIUM". I think this might be a replacement.
Nonetheless, Milwaukee offers a 2 year warranty on their batteries, so contact your retailer or Milwaukee directly.
this how to get a chuck off a drill.look inside the chuck for a screw. it will be a left handed screw.once
you get the screw out put the chuck in a vice . you will need to
squeeze it very tight. then put the drill in reverse and pull the
trigger.if i wont come off you will need to hit the chuck with a hammer
while you are holding the trigger. if you have a bit stuck in the chuck and cant get it out put the chuck in the vice and hit it very hard with a hammer until the chuck falls apart.i work on drills every day ,this is the only way we have found that works
