Lisa Hopkins Posted on Dec 05, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pioneer vsx 405 is a muting there's no sound - Pioneer Audio Players & Recorders
Roger R
Level 3:
  • Pioneer Master 2,005 Answers
  • Posted on Dec 07, 2022
Roger R
Pioneer Master
Level 3:
Answers
2005
Questions
0
Helped
168382
Points
6474
Please check that the mute button on the device or any associated remote control is not stuck in the down/pressed position. If not, then please switch the sound source and test the device for sound again. Otherwise, we can move onto a power cycle of the device.
Thank you.
ADMIN Andrew
Level 3:
Top Expert:
  • Pioneer Master 67,761 Answers
ADMIN Andrew
Pioneer Master
Level 3:
Top Expert:
Answers
67761
Questions
Helped
5266756
Points
386080
This site has all the manuals including Service Manual but you have to register.
https://www.hifiengine.com/manual_library/pioneer/vsx-405.shtml
This similar model has a Mute button
https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-01TXH_OperatingInstructions0606.pdf
No sound is output when an
input source is selected.
No sound output from the front
speakers.
• Check the volume, mute setting (press MUTE) and speaker setting (press SPEAKERS).
• Make sure the correct input source is selected.
• Check that the MCACC setup microphone is disconnected.
• Make sure the correct input signal is selected (press SIGNAL SEL). Note that when PCM is
selected, you won’t be able to hear any other signal format.
• Check that the source component is connected properly (see Connecting your equipment on
page 13).
• Check that the speakers are connected properly (see Connecting the speakers
How to connect my subwoofer to my vsx-405 receiver
Hello
Try to download the user manual to Pioneer VSX & THX user manual. click here to down load the same. You will get details of it connections from the manual.
http://www.dataentryjobs.us/67948.html
Pioneer vsx 405 overloading whenever it turns on I checked the speaker wires and they are all OK.
vsx405 came error dc protection chacked all power transistors c2500 ,a1948 all ok i was disconnect dc detector wire then ok after few minutes one pair burned with c945100 ohms resistors that time not fix heat sink then all replaced power on error overload with speaker and without speakers also coming error disconnect ol wire no chang pease help any expert amplifiers thanks
I have a pioneer usx-405 reciever for a PDf407. It used to work just fine but recently whenever I power it on in keeps flashing "muting". I looked it up online and a forum said I need a remote...
You mean Vsx 405, right? Model numbers are senseless enough without typos.
Are you saying you DON'T have a remote? How did you ever set it up? There are several CU-VSX105 remotes available on eBay, one at $9.99 and expiring in a few minutes (17:12 PDT). If you get this in time you could snipe it at the last 10 seconds.
http://cgi.ebay.com/Pioneer-CU-VSX105-Remote-Control-Receiver-/170642335146?pt=LH_DefaultDomain_0&hash=item27bb1365aa
Many a Pioneer receiver will come up MUTING if it powered down Muting. It's not clear if you have been experiencing unwanted shut-downs. Unwanted Muting or any other command could well originate with an unintended remote control source. Mask the receiver so it can't see other I/R sources.
Why does my pioneer vsx-d557 automatically go into MUTING WHEN I turn it on?
Maybe you have MUTING selected. Turn the volume knob up or toggle the Mute control on the remote.
If it defaults to muting on power up find the manual and search it for a default volume setting.
VSX-1018AH-K 7 Channels Receiver: My VSX 1018AH mutes automatically after 15 seconds...
The exact problem just started with my same receiver, did you get a solution to it in any way ?
My pioneer vsx-d507s keeps turning on mute randomly and I can't turn it off of mute There is no mute button. I would really like the owners manual
I have had the same problem, since there is no "mute" button on the receiver panel. My power cord on the receiver was plugged into my cable box and I was told this is not correct. I unplugged the receiver from the cable box and plugged it into my power surge protector and no more "mute"!!! Hope this helps.
2helpful
4answers
Pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
ExpressFiX
ExpressFiX
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
