Expert
- Posted on Dec 10, 2022
Re: Turboion croc classic flat iron bc-cr1. When I turn...
Error code 021 on a Turboion Croc Classic flat iron indicates a problem with the temperature sensor. This error can prevent the flat iron from heating up properly and may cause it to shut off unexpectedly.
To fix this issue, you can try the following steps:
- Turn off the flat iron and unplug it from the power outlet.
- Use a small screwdriver to open the back cover of the flat iron and locate the temperature sensor.
- Carefully inspect the temperature sensor for any signs of damage, such as bent or broken wires, loose connections, or burnt components.
- If you notice any damage to the temperature sensor, you will need to replace it with a new one. You can purchase a replacement temperature sensor from Turboion or from a third-party supplier.
- Once you have installed the new temperature sensor, reassemble the flat iron and plug it in. Turn it on and check if the error code 021 is still appearing.
- If the error code persists, you may need to contact Turboion customer support for further assistance. They will be able to provide you with more detailed troubleshooting steps and help you resolve the issue.
