Question about Samsung Office Equipment & Supplies
RADF Samsung 6322 doesn't working.
Hello everyone, I have an old Samsung 6322dn, which is perfectly functional except for the RADF, which is as if it is not detected by the machine. I tried unplugging the connector which is similar to a vga and plugging it back in but it is not detected. Do you have any ideas? Thank you all.
Posted by Matteo Serino on
fa cosy
    Passionate:
    Visited the website for 10 consecutive days.
  • 113 Answers
The RADF (Reverse Automatic Document Feeder) on your Samsung 6322dn printer is not working and it is not detected by the machine. Here are a few possible solutions:
  • Make sure that the RADF is properly connected to the printer. The connector you mentioned is a VGA connector, but it could be a different type of connector depending on the model. Make sure that the connector is securely plugged in and that there are no loose connections.
  • Check the status of the RADF in the printer's menu. Some printers have a setting that allows you to enable or disable the RADF. Make sure that it is set to enable.
  • Check the printer's manual or consult the manufacturer's website for troubleshooting steps specific to your printer's model.
  • Verify that the RADF is not jammed. Open the RADF and check for any paper or debris that may be blocking the paper path.
  • Check if the RADF's pick-up roller is not dirty or worn out. The pick-up roller is responsible for picking up paper from the RADF's tray and feed it to the printer. If it is dirty or worn out it may cause paper jams or feed issues.
  • Check the printer's firmware version, if it is outdated, try updating it to the latest version.
  • If none of the above solutions work, it is best to contact a technician or the manufacturer's technical support for further assistance. They will be able to provide more specific instructions for your specific model and can guide you through the process of finding and fixing the problem.
Posted on Jan 21, 2023
Problem on my All-in-one
Replace all electrolytic capacitors on the secondary side of the power supply board. Or replace the power supply board.
How do i do double sided printing on a multi express 6322dn
hello
these two links will help you figure out HOW TO PRINT DOUBLE SIDE COPY
it is all in the control panel on the printer--very simple to use
http://downloadcenter.samsung.com/content/UM/200910/20091027131536375/Guide_EN.pdf
manula in PDF
http://www.samsung.com/ca/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=SCX-6322DN/XAA&srchword=SCX-6322DN
Samsung side to download
please help me keep my job - send me 4 thumbs up
I want to go back to old yahoo i dont like the new one. if i cant i will have a new mail
I don't think there's a perfect solution at the moment. I have been trying to do this in several times, have been to several forums for this but no one can help. There's a work around though, but it doesn't always work for everyone. You can give a try (click HERE.)
Good Luck.
Thanks for using FixYa.
Aug 01, 2011 • Yahoo Mail
Samsung SCX-6322DN power to display "system
Dear
Try to re assembly all harness terminated at main board, Test the machine on toner cart and drum cart opened. System not initialized, check the main board.
Thanks.
Hi Everybody, My 6322DN says "printing...", you
First ckeck the line of the telephone,put another printer and see if you recive the fax on other printer.If you not recive fax possible fax board may be faulty.
2answers
I have an old Califone 1400 all records skip new needle
There's not enough pressure to keep the stylus down in the grooves. Increase the weight (on the end of the arm).
1helpful
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Radf problems on e-studio 232
Hello sir; As you said everything is ok, then the only thing you need to do is solenoid problem, replace it. but make sure exit roller clean enough.
Top Samsung Office Equipment & Supplies Experts
Gary
Gary
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
