Unfortunately, you are probably dealing with a copy protection issue. The digital handshake can't be returned by your KLV3913.
You get the same issue if you connect a HDMI source (Blu-ray player) to a VGA monitor.
I wish that I had better news for you.
Testimonial: "The Roku stick has Model 3810X Also, the TV only has one connection which has a yellow tip. That is were I plugged in the yellow plug from the converter."
Which specific Roku player are you connecting to the TV? The most recent models output HD (720 or 1080 lines) or 4K content. Some of the earlier models of the streaming hardware did work with the converters. However, some converters were faulty out of the box and didn't work with any HDMI output device.
This page,https://www.manualslib.com/manual/371417... , indicates a more important issue that I missed. The composite port (yellow) on the KLV3913 is a AV out port for playing a DVD on another screen. It is not a video input.
The Roku 3810X is also called the Roku streaming stick + player. It's minimum resolution is 1080p. Most of the converters start having issues dropping the signal to the 480 of composite inputs. Cindy Wells
The Roku stick is Model 3810X
