Computers & Internet Logo
Question about The Computers & Internet
I have the indurama 5 burner and the touch panel does not respond accurately when you try to turn on or off the light or fan or rotisserie
David Small
Posted by David Small on
Michael Crain
    Novelist:
  • 76 Answers
If your Indurama 5 burner's touch panel is not responding accurately when you try to turn on or off the light, fan, or rotisserie, it is possible that there is a problem with the touch panel itself or with the connections between the touch panel and the burner's control board. Here are some steps you can try to fix this problem:
  1. Clean the touch panel: If the touch panel is dirty or dusty, it may not be able to accurately detect your finger or stylus when you try to touch it. Try cleaning the touch panel with a soft, dry cloth to remove any dirt or debris that may be interfering with its operation.
  2. Check the connections: Make sure that the touch panel is securely connected to the control board, and that all of the wires and cables are properly connected and not damaged. If any of the connections are loose or damaged, it may cause the touch panel to not work correctly.
  3. Restart the burner: If the touch panel is still not responding accurately, try restarting the burner. To do this, unplug the burner from the power outlet and then wait a few minutes before plugging it back in. This may reset the touch panel and fix any temporary glitches that may be causing the problem.
If these steps do not fix the problem, it is possible that there is a problem with the touch panel itself or with the control board.
Posted on Dec 10, 2022
Jenn-Air propane grill. What causes the rotisserie burner to act up?
Sounds like the burner is cracked and it is lighting back to the injector
Dec 14, 2020 • Grilling
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Can not get rotisserie burner to light
There may be several reasons the rotisserie burner will not light. First, the orifice to the burner itself may be clogged or partially clogged preventing gas flow. There may be a problem with the spark generator, the wire running from the spark generator to the electrode, or the electrode itself. The first thing to check is the gas flow. When you turn on the valve for the rotisserie burner you should hear and smell the gas if it is flowing. Light the rotisserie burner with a manual lighter, if it lights manually, then the gas if flowing.
The seconc thing to look for is a spark from the electrode when you turn or push, depending on the type of spark generator you have. If there is no spark, the it is most likely an ignition system problem. If you have a battery operated spark generator, replace the battery and try again. If the spark generator is a piezo, you have to repalce the spark generator. If you install a new battery, or replace the piezo spark generator, and there is still no spark, then you have to get to the wire and the electrode. Look for bare spots in the wire insulation that would cause a short. Check the electrode for a cracked or broken insualtor. In either case, the wire and/or the electrode will need to be replaced.
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
I have a stainless steel grill. The Rotisserie will light, but the burners will not. I purchased the grill in 2005.I have taken the grill apart and the tubes are clear. There is NO spark going to them. I...
The ignitor wire to the burners my have come loose or has lost full contact. Trace the wiring from the Ignitor Button to the main burners. Note if it loose or has come completely off. Also, check inside the grill at each burner to see if the ingnitors are covered with grease. If that's the case, clean them with alcohol and either a rag or a cotton ball. If all this fails to solve your problem, change the battery in the Ignitor Button with a brand new Alkaline type battery.
Hope this helps solve your problem. Happy Grilling!
CalFlame 4-burner convection BBQ rear rotisserie burner does not work. Converted to natural gas. There is a spark but gas will not ignite. Held match to burner and it would light but would go out when...
Check the air shutter adjustment on the rotisserie burner. It may be starving for air. Also make sure the burner is properly positioned over the orifice. When it was converted, it may not have been put back into place correctly. Also, it's possible the orifice may have been re-drilled out at the wrong size for natural gas. If you know the rotisserie burner BTU rating, I can look up the correct orifice hole size to check if it's right. Douglas
1helpful
Rotisserie burner won't light
It could be a dirty or inop spark electrode. Also could be weak batteries in the spark igniter.
Before you start you should make sure that the ignition system has fresh batteries. The batteries are usually located within the igniter button but not always. Some BBQs will have a battery pack located somewhere on the BBQ and others you can remove the igniter button by turning it left to reveal the battery.
First verify that the rotisserie burner can be lit manually. Take a BBQ lighter or long stick match and then put the flame right at the base of the burner where the electrode is and then slowly turn on the burner valve. It should light within four seconds. If it does not then shut the burner off and check for any restrictions in the gas line for the burner.
If it does light with a match then the spark electrode could be dirty, out of position or simply the wire for the ignition system is loose. Press the igniter button and watch the electrode for a good bright spark at the burner. If you do not see any spark you can verify that the igniter wire has not come loose and also gently adjust the position of the electrode end a little bit closer to the burner using a pair of needle nose pliers(It should not be touching the burner). It does not need to touch the burner but have a really small gap.You can use a small wire brush to gently clean the electrode of any debris that might be causing a weak or no spark
If you are unable to remedy the non-spark issue all is not lost. You can still use the manual lighting procedure I described to light the burner. And remember to be careful when trying these procedures. I do not want you to get injured from delayed gas ignition. Be careful and have a safe holiday.
1helpful
2answers
Ducane 3400042 lighting problems
Good answer... but remember (if you have the regular burners on... The Rotisserie will not light.) 1. Cut all knobs off... Then push and hold in Rotisserie button as you turn to high.
2. Press ignition button, until you hear rotisserie ignite. 3. Keep holding in the rotisserie button until the thermostat realizes the gas is on and burning. (IT must get hot enough to keep gas flowing.) Hope that helps, Dave
Top The Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
NADARK
NADARK
nexrad_chris
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
