Televison & Video Logo
Devant 50DTV700 & 50UHD 202 SERVICE MODE...
I want to set the tv on and when unplug turn it plug again automatically on....please help
Devant LCD TV: channel always set to a certain channel (ex. channel 2) with out signal upon re-plugging or turning TV "ON". Is there a default channel setting? how to? thanks!
Do a hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
1helpful
2answers
TV REMAINS IN "STANDBY MODE" NO PICTURE OR SOUND
remote batteries
turn off at the wall ...unplug..plug back in ... start again
Devant lcd tv 40 inches
Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This will make it a hard reset. If you wish to do a system reset, you should enter its service mode option.
google.com/+GopakumarGopalan
1helpful
2answers
1helpful
I have a samsung tv , and im setting up my [email protected] , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Devant LCD TV: Characters appearing on the screen while watching
I have 2 Devant TV 32CL900 and 32DX850 but I've never experience this kind of problem. What kind of character appears?
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
2helpful
3answers
Zenith H2533Y TV Entering Service Mode
wHEN YOU GET THE MENU UP YOU HAVE TO HOLD THE MENU BUTTON DOWN UNTIL THE MENU DISAPPEARS THEN ENTER 9876 ENTER. YOU CAN ALSO JUST AUTO PROGRAM THE SET AND IT WILL COME OUT OF SERVICE MODE.
LADY TECH
Tv comes on for a second, then goes off.....
to enter the service mode . while pressing the vol-up and ch-up buttons at once, plug the AC cord into the wall socket and switch on the main power . now the TV set is switched on and enters the service mode. to exit the service mode, shut the television off by pressing the power button.
7helpful
4answers
Gemini universal tv remote
I lost a few manuals myself. Gemini Universal Remote Control Programming Codes ------------------------------------------------ 1.Locate the 3-digit brand code from tables below. 2.Press and HOLD the RCL and ENT keys simultaneosly, until the red indicator turns on (3-4 sec) 3.Select the type of device you are programming by pressing the TV, VCR, CTV or AUX key. 4.Enter the 3-digit brand code number. If a valid code was entered, the indicator light will go off. 5.Test your Gemini remote,by pressing PWR key. Repeat 2-5 with new code number if not responding. Autosearch Instructions: If your remote has an auto search on it. 1. Turn ON the device you wish to program the Gemini to operate. 2. Press and HOLD the RCL and ENT keys simultaneosly, until the red indicator light turns ON. 3. Select the type of device you are programming by pressing one of the TV, VCR, CTV or AUX mode keys. Now enter one of the following device type search codes: TV-990, VCR-992, Cable-994. 4. Aim the Gemini at the device and press the red PWR key. If your device turns OFF, press the appropriate device mode key again,(TV,VCR,CTV or AUX),to lock in brand code for that particular device and exit from the programming mode. 5. If the device doesn't respond, press the VOL"+" key once to advance to the next brand code. Now press the PWR key again. Remember to immediately lock in your code when the component turns OFF by pressing the proper mode key. Continue repeating steps 4&5 until your device turns OFF. I hope this helps you out, Good Luck to you. TV Codes ADMIRAL 400,530 MITSUBISHI 020,160,180,190,230,240,580 AKAI 160,240,550 MTC 140,180,300,310 AMARK 390,590 NATIONAL 010,270,420,510,570,610 AMSTRAD 110 NEC 180,190,240,300,310,580,620 ANAM 170 PANASONIC 010,270,420,510,570 ANAM NATIONAL 420 PHILCO 080,120,130,180,270,240,270 AOC 180,240,300 300,390,450,490,540,590 BELL&HOWELL 530 PHILIPS 080,120,130,180,270,300,450 CANDLE 060,080,300,310 490,540,560,590 CENTURION 190,580 PORTLAND 390,590 CITIZEN 060,080,140,300,310,390 PROTON 240,390 CONCERTO 310 QUASAR 010,420 CONTEC 170,260,470 RADIO SHACK 070,170,190,390,410 CORANDO 390 RCA 090,180,240,400,500,600 CORONADO 590 REALISTIC 070,150,170,190,390,410 CRAIG 170 SAMPO 190,300,580 CURTIS MATHES 030,140,190,300,390,470 SAMSUNG 140,180,190,300,310,390,410 590,650 580,590 CXC 170 SANYO 200,430,460 DAEWOO 180,340,380,390 SCOTT 020,190,390,580 DAYTRON 190,390,580 SEARS 020,140,190,200,210,390,430 ELECTROHOME 160,390 440,460,590 EMERSON 020,110,150,170,240,280 SHARP 000,050,070,390,590 330,390,470,590,650 SONY 350,550,640 ENVISION 300 SOUNDESIGN 080,240 FISHER 200,460 SSS 170,180 FUNAI 020,170 SYLVANIA 080,120,130,190,270,300,360 GE 010,040,290,400,420,630 450,490,580,630 GOLDSTAR 180,190,240,310,390,590 TATUNG 420 HITACHI 100,260,310,320,390,590 TECHWOOD 310 INFINITY 270 TEKNIKA 020,060,080,140,160,170,180 JBL 270 270,310,390,480,530 JVC 030,250,370 TELERENT 390,530 JC PENNEY 040,180,190,240,290,300 THOMSON 400 390,400,440,500,630 TMK 240,310 KLOSS 490 TOSHIBA 140,200,210,220,440 KMC 390,590 TOTEVISION 390 KTV 170,240,390,590 UNIVERSAL 040,290 LLOYTRON 390 VIDTECH 180 LODGENET 530 WARDS 020,040,070,120,130,180,190 LOGIK 530 240,270,290,300,390 LOGIX 530 YAMAHA 180 LUXMAN 310 YORX 190,580 LXI 000,190,210 ZENITH 520 MAGNAVOX 080,120,130,190,270,300 390,450,490,580,590,630 MAJESTIC 530 MARANTZ 160,240,300,450,490 MEMOREX 530 MGA 020,160,180,190,230,240,300,580 VCR Codes AKAI 002,052,112,202,372,402 MULTITECH 072 AMSTRAD 072 NATIONAL 272 ASA 022 NEC 202,252,292,302 AUDIO DYNAMICS 202,292 NORDMENDE 202 AWAI 392 PANASONIC 272 BROKSONIC 282 PENTAX 332 CANDLE 022 PHILCO 272 CANON 272 PHILIPS 272 CITIZEN 022 PIONEER 252 CRAIG 092,182 PORTLAND 232 CURTIS MATHES 272 QUASAR 272 DAEWOO 062,232,342 RADIO SHACK 022,072,092,142,152,182,272,312 DAYTRON 232 RCA 032,182,272,422,452,492 DBX 202,292 REALISTIC 022,072,092,142,152,182,272,312 DUAL 202 SABA 202 DYNATECH 072,142 SAISHO 242 ELECTROHOME 022 SALORA 212 EMERSON 042,072,082,102,112,132 SAMSUNG 172,182,342,412 192,242,282,472,482 SANSUI 202,252 FERGUSON 202 SANYO 092,312,382 FINLUX 072 SCHAUB 202 FISHER 092,322,332 SCOTT 132,212,242,342,432 FUNAI 072 SEARS 022,032,092,162,312,322,332 GE 182,272,422 SHARP 142,222 GOLDSTAR 022,292 SONY 122,252,352,362 GRAETZ 202 SYLVANIA 212,272,452 HARMON KARDON 292 SYMPHONIC 072 HITACHI 032,072,202 TASHICO 022 INSTANT REPLAY 272 TATUNG 202 ITT 202 TEAC 072,292 JCL 272 TEKNIKA 022,072,272,502 JENSEN 202 TELEFUNKEN 202 JVC 012,202,252 THOMSON 202 JC PENNEY 022,032,272,292,302 THORN 202 KENWOOD 202,252,312 TMK 042 LLOYD 072 TOSHIBA 162,202,212,342 MAGNAVOX 272,452 TOTEVISION 022,182 MARANTZ 272,292,452 UNITECH 182 MARTA 022 VECTOR RES. 212,292,302 MEI 272 VIDEO CONC. 302 MEMOREX 022,072,272 VIDEOSONIC 182 MGA 022,192,212 WARDS 022,072,142,182,222,272 MINOLTA 032 YAMAHA 202,292 MITSUBISHI 022,192,212,442 ZENITH 122,252,432 MTC 072,182 CTV (Cable TV) Converters Anvision 104 Realistic 504 Cablestar 104 Regal 444 Diamond 444 Regency 164 Drake 144,284 Rembrandt 474 Gemini 244,274,474,534 Samsung 094,374,474 General I. 004,034,044,204 Scientific Atlanta 074,524 GI/Jerrold 004,014,024,034,044,204,234,244,354 Sprucer 494 GI/Starcom 394 Standard Component 474 Hamlin 424,434,444 Starcom 014 Hitachi 414 Stargate 484 Kate Vision 474 Sylvania 114 Macom 184,304,324 Tocom 194 Magnavox 054,104,124,344 Toshiba 184,264 NSC 474 Tri-Vision 124,234,354,364,384 Oak 294 Unika 154 Panasonic 334,494 United Cable 014 Paragon 454 United Satellite 224 Philips 054,104,124,134,174,214,254 Videoway 314 Pioneer 064,084,094 Viewstar 054,104,124,134,174 Pulsar 484 Zenith 144,184,404,464,514 Randtek 104
Top Televison & Video Experts
Marvin
Marvin
