Hello everyone, I have 2 questions please: a) all of a sudden my pioneer is changing among radio, spotify, bluetooth, AUX by itself...Meaning if I wanted to listen to radio instead of bluetooth, then i hit the same button till it gets to "radio", Now the sterero is randomly doing this by itself w/o me touching a button. I reset the whole thing but problem is not fixed. what should i do? b) i have 4 speakers in the car. now i no longer get any sound from the rear speakers and when i go to the settings i only see the "balance" feature where sound can be changed from left to right vice versa for the front speakers. What happened to the rear speakers? Thank you !!
Hi there! It sounds like you're having some issues with your Pioneer stereo.
For the first issue, it could be due to a faulty connection or a software issue. To troubleshoot, first check all the connections between the head unit and the speakers to make sure they are securely connected. If the connections are secure, then check the wiring connections to make sure they are not loose or frayed. If the wiring connections are good, then the problem could be with the head unit itself and you may need to contact a professional for further assistance.
For the second issue, it could be due to a faulty connection, a wiring issue, or a software issue. To troubleshoot, first check the speaker wires to make sure they are connected properly and not loose or frayed. If the wires are secure, then you should check the setting on your amplifier or stereo to make sure the rear speakers are enabled. If the rear speakers are enabled, then the problem may be with the wiring or with the head unit itself and you may need to contact a professional for further assistance.
Posted on Jan 04, 2023
