Water Heaters Logo
Question about Water Water Heaters
Richmond gas water heater produces hot water for 5 minutes and cools down. Seems to be a consistant issue the past 3-4 months. I replaced thermo coupler 8 months ago
Posted by Curt Reiter on
How do I make the flame of my water heater pilot bigger, it seems to little and goes out every day. I have installed a new thermo coupling but the pilot flame is small. Is there a place to increase th
If the pilot is going out, it may be from lack of combustion air intake. Make sure you have fresh air in the water heater room...one within 18 inches from the ceiling, & one within 18 inches from the floor. The size of the openings is determined by the BTU's of the water heater.
I keep getting a code 13 and no hot water after about 3 min. Vent is clear??
Undersized gas line?
Temperature set too high?
Haven't kept up with regular maintenance?
Tankless older than 5 years?
Hard water over 7 grains?
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Very minimal hot water being produced from my water heater
1) Clean air intake, and do required yearly maintenance.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Gas control valve thermostat could be going bad, causing disruption of gas to pilot, and uneven heating of water.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
3) Without knowing brand and model number that shows on label on side of tank, it is difficult to add specifics.
Richmond power vent will not stay lit, the bunrer will lit than after about 5-10 min. it goes and tries to relite and than goes into lock down. after it about 5 min. you can reset it and it will do the...
Richmond-Ruud-Rheem
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
It sounds like you've read the manual.
And cleaned the burner parts according to manual.
You replaced thermal reset, but system is still tripping, so either the gas valve and tubing are bad, the thermocouple is bad, or there is a problem with gas pressure, or gas line.
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Richmond LP PowerVent water heater stops heating. LED's A&B, indicating it has cycled three times without ignition. Watching it go through its cycle, the heat plate glows, hear a click, no flame,...
just an educated guess but id say you have one of two possible problems , gas valve bad or flame proof device is bad
the second cause is very common !! so common in fact theres a spare hanging on the side of mine !!!
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
