Televison & Video Logo
There is no power to the front panel
Just changed out circuit board
  • Jim Dufrene
    Jim Dufrene Dec 01, 2022
    I get paid more than $90 to $100 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $21k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.…………>> http://www.LiveJob247.com
2answers
No power o front panel no led radout no 110 or 220 or weld out put
Check switch continuity inside the control panel.Check all the switches.
Does not cool on gas or 110 volt
Do you have any lights working on the front panel? If not most lower circuit boards have a small fuse on the circuit board. shut down ALL power before checking for the fuse.The lower board has both 115 volts as well as 12 volts. If the lights are working on the front panel then most likely the lower circuit board is faulty and will need to be replaced.
2helpful
4answers
Power button broke gfdn240el1ww
There are two main pieces to the front panel for the GFDN240EL1WW dryer-- the plastic panel and the circuit board. The actual replacement part is: Control Panel WE19M1687. The panel can be purchased for from places like partselect.com or repairclinic.com or Amazon or even EBay, etc. for $100-$200+.
The power button is just a piece of plastic mounted to another piece of plastic; it is not electronic. When pushed, it presses against the circuit board, which then turns the unit on/off. When the power button breaks, it typically means the little plastic button has broken off from the plastic panel. Most likely, the problem is the mount point for the button and the button is actually re-usable.
A cheaper quick-fix is to:
  • Remove top screw from back of the front panel
  • Remove main front knob from the panel
  • Remove screw from behind the front knob
  • Grab both sides of the front panel and push/pull up to remove the panel
  • Disconnect the block connector (power) from the circuit board after removing the panel
  • Locate the power button and mounting position
  • Inspect to see if it looks like you can glue the button back into place
  • Buy a small tube of loctite Stik'n Seal Ultra Universal Adhesive
  • Put some Stik'n Seal on the button mounting point for the power button (be generous)
  • Press the button onto the mounting point and hold for a few minutes
  • Add more Stik'n Seal around the edges of the mounting point and the button mount after you have held the button in place long enough so that it sticks
  • Let the whole thing dry for several hours (instructions on the adhesive say 24hrs
  • If you are worried about the button staying seated while the adhesive sets, you can always try tape it into place
  • When dry, replace the front panel by reversing the steps above used to remove the panel: connect the power block, slide the panel back into place, replace the front screw and knob, replace the top screw in the back of the panel
No power for lg wm2277hw
Power supply has failed to the panel board and it can due to failure of the board, failure of the surge filter or the power circuit.
check the panel and if there is short within the board then the panel must be replaced
1helpful
3answers
My akai tv model lct3785ta will not turn on
Ok.. What is the status of the power LED at the front. Does it blink, change color a few seconds after its turned on? Do you notice any clicking noise from the set?
Please provide this info so that we can continue with the diagnosis.
Sai.
1helpful
2answers
There is no power on the unit although it is plugged into a live outlet.
Possibly you have a burned out control board or a burned out control panel. I had a similar problem. I changed the control board first and it ended up being the front control panel.
Nothing worked on the front panel. No lights came on and no beeping sound when you pushed any button. I should have done the front panel matrix test first in the manual. But the manual lead me to believe only one button or one light would fail. For some reason the whole front panel stopped working.
If you problem is the same. Do the matrix test on the front panel. If it checks out okay then it's your control board. I believe if the motor control board is the issue you would still see the front display working.
The fuse is on the motor control board. Do not try checking anything till you view the manual below.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
2answers
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Hr22 hd dvr receiver has no front panel lights
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Mdb8750aws dishwasher dead, no front pannel lights, no functions
I just fixed my washer!!! had power to control board. romoved lower panels openned connection box ( one screw) cut and cleaned wires and reconnected to power line that runs to the plug. Did it twice and finally got a good connection started right up. WAS just about to order a new circuit board. SAVED MYSELF $100.00 !!!!!
Open Questions:
Top Televison & Video Experts
Marvin
Marvin
