Cant get any channels to pick up
I recommend that you first scan the weather band to make sure that the scanner is working properly. You should be able to pick up one of the NOAA broadcast frequencies just about anywhere in the USA. No reception? Your scanner probably needs professional repair. If you receive weather broadcasts, make sure that you have active frequencies for your area programmed into the scanner. You can find a comprehensive database of active frequencies, and a lot of other useful scanning information by visiting:
www.RadioReference.com
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC95XLTom.pdf
Bill B.
Listening in since the 60's
