Baby Gear Logo
Question about Baby Gear
One of my walker bt won't turn on - Baby Gear
Posted by Scott Boise on
Darrin S
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
  1. Check to make sure that the earbud is fully charged. If it is not, charge it for at least 30 minutes before attempting to turn it on again.
  2. Make sure that the earbud is properly paired with your device. If it is not, try pairing it again.
  3. Check to see if the earbud is properly inserted into the charging case. Make sure that the charging contacts on the earbud and the charging case are clean and free from debris.
  4. Try resetting the earbuds by following the manufacturer's instructions.
  5. Try connecting the earbuds to another device to see if the issue is with the earbuds or the device they are connected to.
  6. If none of the above solutions work, it is possible that the earbud is malfunctioning and will need to be repaired or replaced. Contact the manufacturer for further assistance.
It's important to follow the instructions carefully and if you have any doubts or difficulties, consult the earbuds user manual or contact the manufacturer for assistance.
Posted on Jan 24, 2023
Hi I am after the technical specifications of Walker mower parts in particular part no 7234-2 which is a micro v belt I can't just go to a dealer and get one so if I get the specs I can try elsewhere
Have you tried going to Bing or Google (my preference) and typing in the Walker Mower Parts and let Google search for them. Have had tremendous results this way
Feb 05, 2018 • Garden
I have just filled in a form but it asks for my account number which is EA 30002 7860 & it won`t accept that.
First of all I don't advise advertising any personal information online in a public forum, it would be for your own safety, such as account numbers.
Because the problem is with a BT website and a BT account from what I can tell the best thing you can is contact BT, the link below will take you to the contact page of their website:
BT com Contact BT
AKG K 830 BT
My akg show always green lite but it not charge
5helpful
2answers
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Hair stuck baby walker
Hi ,
I’ve spent days trying to clean out our baby walker wheels. There was so much hair inside wrapped so tightly that it was impossible to remove. After researching and not getting so much information but the usual steps that did not work for me. I thought, what’s good to dissolve hair. DRANO!! So I figure why not try.
I soaked the wheel in drano overnight, the following morning, the wheel was much looser but still had a lot of hair inside. Repeated the same step overnight and left the wheel in hot water afterwards for a few hours. After grab the wheel, and keep spinning it and twisting in different rotation. Hair will begin to fall out and wheel becomes much looser. Keep spinning as much as possible throughout the day. And finally the wheel is fixed!! ?? .. if hair is still trapped inside, just keep leaving it in drano and hot water, repeat as needed!! Hope this helps!!
Nov 21, 2012 • Baby Gear
3answers
My bluetooth wont work on my sciphone
Make sure that it's charged. Go thru the instruction on how to program your BT for your phone and make sure that your phone is set to pickup BT. the default passcode for your BT to set to your phone is 0000 or 1234.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Top Baby Gear Experts
Marvin
Marvin
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a Baby Gear Expert? Answer questions, earn points and help others
