Looking for instructions for a Refrakta Wake up light clock model A11LH
2helpful
Can't turn off the alarm
There are two alarms, and the steps are the same .
Look on the face. On the left of the big numbers are two symbols, a 'bell' and a 'music note'. That's WAKE 1. On the right of the big numbers are two symbols, a bell and music note. That's WAKE 2. If any of these are on, then one (or both) alarms are set to repeat.
Stopping repeat Wake 1 alarm. Click the Wake 1 button (on the top) several times, while looking at the face. Notice the circles that light up. It will switch back and forth between bell and music note each time you press the Wake 1 alarm button.
HOLD DOWN the WAKE 1 button on the top, until both lights are off. The Wake 1 alarm is now off.
Wake 2 alarm: Same steps, but for the green circles on the right side of the face.
Get a piece of paper, write "HOLD DOWN WAKE BUTTON to stop repeating alarm" and tape it to the back of the clock.
19helpful
I have model #7-4837B AM/FM radio alarm clock. User manual has been misplaced and I am unable to disable the alarm.
On the top of the alarm clock is a CANCEL button. Press the button and the light next to the WAKE MODE indicator on the front of the clock will begin to flash. Press the WAKE MODE button on the top of the clock. The WAKE MODE indicator will go out and the alarm is off. If you want the alarm back on just press the WAKE MODE button again.
GE doesn't make this kind of product any longer but
on their site they say to call 1-800-447-1700 for assistance. Maybe someone there can find a copy of the instructions for you.
6helpful
Instruction on how to set the clock and wake up time
I couldn't find the manual for your specific model, but this one will likely work for you:
http://www.skyscaninfo.com/content/manuals/26-model-86722alu.html
Bill B
3helpful
Peaceful Progression Wake Up Clock manual Hammacher Schlemmer
go to the Hammacher Schlemmer web site (www.hammacher.com) and in the search box insert "peaceful progression wake up clock".
Just below the description of the clock there is a heading "instruction manual", click on this and download the instructions.
Jan 23, 2010 • Watches
13helpful
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
shows on the display.
2. Press REV or FWD to set the clock
time. The time decrements or
increments will follow by a faster rate
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
This unit allows two wake times to be set.
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
wake time. The time decrements or
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
3helpful
Need to reset dual alarm to wake up
http://www.emersonradio.com/owners/SmartSet%20Series/ Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson web page of the smartset clock/radios. Find you model number smartset clock/radio and open the link to download a pdf copy of the owners manual.You can use the print function on your computer to make a pdf copy of the owners manual for you own use. I hope this information helps you with your problem.
43helpful
Can't disable alarm feature on colock radio
Just press "Cancel" once and then press the "Wake Mode" button until the selector light cycles through the the music or tone modes...and then disappears.
23helpful
5answers
Wacky wake up alarm clock instructions
Hold down the "time set" button until the time on the clock flashes. Then use rev or fwd to set the time. Press the "time set" button again once you have the correct time. You can do the same to set the alarm by holding down the "alarm set" button.
Jan 03, 2009 • Watches
106helpful
4answers
GE Model 7-4837B
press the Cancel button located on the top of the alarm clock (the light next to the wake mode indicator on the front of the clock should start flashing). Then press the WAKE Mode button on the top of the device. The wake mode indicator on the front should now be off and the alarm deactivated.
To turn the alarm back on, simply press the WAKE Mode button on the top of the device.
 Grubhead
Grubhead
Marvin
Marvin
