Electrolux Ecovalve EWF1087 wont progress past wash
My Electrolux Ecovalve EWF1087 stops at the end of the wash cycle and will not progress to the rise. The timer continues till zero, but the machine does nothing.
You can manually set it to run from rise and it will complete the rest of the cycles.
So all functions seem to work, but something stops it from progressing from Wash to Rinse.
In the last 6mths I have replace the motor brushes, water level sensor and the main CPU.
Without seeing what make and model... Pressure hose to the water control might be plugged or tap on the control panel with a rubber mallet to see if points in that sensor are stuck. Try setting it to a smaller load size.
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
Make sure you put the filter cap on tightly There is a little plastic piece it has to line up with, Recheck all the hoses. Remove the access panel and start the washer see where it is leaking. If you need further assistance please comment me back.
My electrolux EWF1087 is leaking water from the front door, I cannot see any damage on the door seal although I never noticed its folded over and full of dirt. Do I need a new seal ?
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
