Passionate:
Visited the website for 10 consecutive days.
Expert
Re: canon ir2520 jamming in the exit tray
If your Canon IR2520 is jamming in the exit tray after initializing the machine, it could be caused by a few different issues:
Paper tray: Make sure that the paper tray is loaded correctly and that the paper is not jammed or loaded incorrectly. Also, check if the paper tray is not overfilled or if the paper is not wrinkled.
Pick-up roller: The pick-up roller is responsible for picking up paper from the tray and feed it to the printer. Check if it is dirty or worn out.
Exit guide: The exit guide is responsible for directing the paper out of the machine. Make sure that it is not blocked or bent, which could cause the paper to jam.
Fuser: The fuser unit could be malfunctioning. The fuser is responsible for heating and fusing the toner to the paper. If it is not working properly, it could cause paper jams.
Feed rollers: The feed rollers are responsible for feeding the paper through the printer. Check if they are dirty or worn out.
Paper jam sensor: The paper jam sensor may be malfunctioning. If the sensor is not working correctly, it may not detect a jam and the printer will continue to try to feed paper through.
It is recommended to check the copier's manual or consult with the manufacturer's technical support to troubleshoot the problem. They may provide more specific instructions for your specific model and can guide you through the process of finding and fixing the problem.
These are general suggestions and your specific case may require different actions.
Regenerate response
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us:http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
Error
Codes - Toshiba 2860
"E01"
Paper jam inside machine.
"E02"
Paper jam near the fuser.
"E03"
Paper jammed inside machine when power supply is switched on.
"E04"
Front cover open while copying.
"E05"
Paper jam near the aligning roller
"E08"
Paper jam at stacking area in the ADU
"E11"
Paper feeding jam at the ADU
"E12"
Manual feeding jam
"E13"
Paper jam from cassette 1
"E14"
Paper jam from cassette 2
"E15"
Paper jam from cassette 3
"E16"
Paper jam from cassette 4
"E17"
Paper jam from cassette 5
"E19"
Paper jam from the LCF
"E21"
Paper jam in transport route 1 (LCF)
"E22"
Paper jam in transport route 2 (COPIER)
"E23"
Paper jam in transport route 3 (ALIGNING)
"E25"
Paper jam in transport route 4 (PFP)
"E71"
Original feed jam in ADF
"E72"
Original transporting jam in ADF
"E73"
Original exiting jam in ADF
"E75"
2nd original feeding jam
"E81"
Paper jam before sorter
"E82"
Paper jam in sorter
"E83"
Sorter early arrival jam
"E84"
Paper in sorter when power is turned on
"E85"
Joint open jam while copying
"E88"
Paper jam outside the sorter bin
"C01"
Abnormal operation of the copier main motor
"C04"
Abnormal operation of the PFP main motor
"C05"
Abnormal operation of the ADU main motor
"C11"
Abnormal operation of the ADU side motor
"C12"
Abnormal operation of the ADU end motor
"C13"
Abnormal operation of the upper cassette tray
"C14"
Abnormal operation of the lower cassette tray
"C15"
Abnormal operation of the PFP upper cassette tray
"C16"
Abnormal operation of the PFP middle cassette tray
"C17"
Abnormal operation of the PFP lower cassette tray
"C18"
Abnormal operation of the LCF tray
"C21"
Optics carriage initialize error
"C22"
Lens initialize error
"C23"
Mirror initialize error
"C26"
Faulty exposure lamp
"C33"
Easy set-up is failed
"C35"
Developer material exists at the transfer separation adjustment
"C41"
Faulty thermistor or heater
"C43"
Faulty thermistor
"C44"
Faulty heater
"C45"
Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
E, 0, 3
Summary If the Paper Output Tray is closed, open it. The machine resumes printing.
Hello... i have a copier IR6570. If i load the paper from tray 1, it always jammed. But if i load from other trays, everything goes well. Can anyone help me, please...?.
try the bypass.... if unable to print via bypass then clean rubber bypass feed rollers with alcohol... next step... see if it jams at the finisher... if so set the machine to exit from an internal tray... if it has one...
