Inlet screen clean with strong water flow through unit when hot water is demanded. Blower fan come on for about a minute, then shuts off. Burner never fires no flame observed through sight hole, vent chimney remains cold. Flame detector and igniter probes polished with 2000 grit emery. Panel power reset several times. No LED code is being thrown. Water flow sensor has been replaced. NG gas valve is on. What should I check next? Richard
It sounds like there may be an issue with the burner on your Takagi T-KRj water heater. Based on your description, it appears that the burner is not firing, despite a strong water flow through the unit, the blower fan comes on for a minute, then shuts off and no flame is observed through the sight hole.
There could be multiple reasons for this, and it is essential to investigate further. Here are some things you can check next:
If you have checked all these things and the issue persists, it's best to call for professional help as it may require specialized knowledge and skills to troubleshoot and fix the problem. It's important to note that working on gas appliances can be dangerous, and only qualified and licensed personnel should work on them.
My Colman air and heater won't cut off what do I do
