If you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. According to your description, low voltage circuit (220V or 110V) works well (light, turntable...).
Obviously the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or sometimes in interlock switch assembly or PC Board.
First, you must be sure which diode is blowed, reactifier or protect diode.
To check magnetron following this procedure:
Discconect the mains supply.
Check that the capacitor is discharged (by resistor 100 ohm / 10W or more).
Discconect the magnetron.
Measure the resistence between the disconnected terminals (should be app. 0.5 ohm).
Measure the resistance between the supply terminals (both) and earth. The resistance should be infinite.
Dado
