Televison & Video Logo
Amazon fire stick is stuck on the logo page??
My fire stick I connected to the tv and stay stuck on the logo Amazon's page . What I can do to fixed? I already try leaving on for 24 hours nothing happens, what i can do ??and I try unplug and plug in again nothing happens either. What can do to make work??
Roger R
  • Televison & ... Master
  • 2,005 Answers
please ensure that the firmware on your tv has been updated. You can also check that the internet is accessible through your tv by attempting to use other apps on the tv. Otherwise, you might consider power cycling your tv in order to help overcome the issue.
Thank you.
Posted on Nov 30, 2022
2answers
How can I fix the television remote control to access my Amazon Fire Stick please?
Pair Firestick remote to TV
Go to Settings on your Fire TV. Select Controllers & Bluetooth Devices. Select Amazon Fire TV Remotes. Press and hold the Home button for 10 seconds to pair your remote.
Amazon.ca Help: Pair Additional Fire TV Remotes
Videos as well
https://www.google.com/search?q=television+remote+control+to+access+my+Amazon+Fire+Stick
2answers
Can i connect fire stick to pdp r06xe as my tv has no hdmi port
STEPS TO USE AMAZON FIRE STICK WITHOUT HDMI PORT
  1. Connect your Amazon Fire stick's power cable into the power supply.
  2. Plug your HDMI converter to the power supply.
  3. Now, connect the Amazon Fire TV stick into the HDMI port.
  4. Plug the RCA cords from the HDMI converter to the ports available on your TV.
https://fix-my-tv.com/amazon/how-to-use-amazon-fire-stick
My fire stick wont load past the fireTV stick logo. Please help
Here's a link to a discussion on Amazon where users are having the same issue as you're having. Lower down on the page there are a few responses that might fix your problem. Fire TV Stick stuck in boot logo unrooted
What do I need to do to get my fire stick working again
Please contact Amazon support for this question.
3answers
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
2answers
Wont accept registration details
Amazon.com Help: Basic Troubleshooting for Amazon Fire TV
https://www.amazon.com/gp/help/.../display.html?...
Amazon.com, Inc.... five seconds. Or, open Settings > System > Restart from the main menu. ... Note: External storage options are not available for Fire TV Stick. First, make sure ...
Amazon.com: Customer Discussions: Connecting Fire Stick to Wifi
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Dec 21, 2014 - No questions asked. .... I have the same problem because my network is considered open ... I'm trying to connect to a friends Xfinity wifi with fire tv stick, I have my laptop, Ipad & phone all working thru it but TV Stick won't. ... Mine wouldn'taccept password until I connect the HDMI extender - works fine now. Fire TV Stick keeps asking for ...
Jan 3, 2015
KIndle Fire HD won't accept ...
Nov 2, 2014
How do I re-register my new ...
Mar 11, 2014
kindle won't connect with wi-fi
May 7, 2012
More results from www.amazon.com
2answers
Why can't I register it?
Fire tv stick can't register - Amazon.com
https://www.amazon.com/gp/.../ref=cs_hc_g_tv?...
Amazon.com, Inc.Received my new fire tv stick today. I'm able to get past the wifi connection screen. But registering it with my Amazon account is I'm possible. Tried over 50 times ...
Amazon.com, Inc.Make sure your Amazon Fire TV device is registered to your preferred Amazonaccount. To verify your registration ... Can't Access External Storage. Note: External storage options are not available for Fire TV Stick. First, make sure you're using ...
Amazon.com Help: Can't Connect to Wi-Fi
2answers
Can i install a amazon fire tv stick the u s b will not plug in
Amazon.com: Customer Reviews: Amazon Fire TV Stick
www.amazon.com/Amazon...Fire-TV-Stick/.../B00GD...
Amazon.com, Inc.It doesn't even play all the games that can run on the Fire TV box. Also note ... Q: CanI use my TV's USB port to power the Fire TV Stick? ... A USB port on your TV or other equipment probably will not work. ..... You can plug the Fire Stick's USB cable into theUSB port on your TV and it should work (depending on your TV ).
Amazon.com: Customer Discussions: Fire stick and Samsung TV issues
www.amazon.com/forum/fire?cdForum...cdThread...
Amazon.com, Inc.Getting a brand new replacement from Amazon did not help, seems to be some other HW or SW issue. Anyone else run into similar issues? ... I also have a Samsung TV and the Fire Stick is not recognized through HDMI or USB connections. .... Can youplug the HDMI extender cable into your TV and will the Fire TV stick fix
Top Televison & Video Experts
Marvin
Marvin
