Blower comes on, about 30 seconds later, I hear a click and the far right flame comes on, 5 seconds later, the flame goes out. Throughout the day, these steps repeat and eventually all flames come on. Why don't all flames come on the first time? I have cleaned the flame sensor with steel wool and no difference. Thanks.
It sounds like there may be an issue with the ignition system of your RUUD Silhouette II UGLH-15EARJR furnace. Based on your description, it appears that the furnace is not always coming on correctly. The blower comes on, but after 30 seconds, you hear a click, and the far-right flame comes on, but it goes out after 5 seconds. Eventually, throughout the day, all the flames come on, but they don't come on the first time.
This problem could be caused by several issues, including a malfunctioning ignition system, a problem with the flame sensor, a dirty or clogged burner, or a problem with the gas valve.
To troubleshoot this issue, I would recommend checking the following:
It's important to note that gas appliances are complex systems that require specialized knowledge and skills to troubleshoot and fix. If you are not comfortable working on these issues, it's best to call for professional help, as it may require specialized knowledge and skills to troubleshoot and fix the problem.
Update: fixed. I replaced the flame sensor a couple weeks ago and it didn't make any difference. I noticed one day that if the 1st burner lit and I blew on it, it would ignite the rest of the burners. The fix was to replace the burner halves assembly. In my case, part AS-60993-06. The old one had gotten rusty between the 1st and 3rd openings, not allowing gas to go from 1 to 2 sometimes. I bought the part from a local RUUD parts seller, but it looked like it was poorly made - I had to make a couple minor modifications to make it fit.
